Rear sub frame bolt tape
Started by john302, April 17, 2011, 07:35:01 PM
john302
Does anyone know what the width of the tape that covers the rear sub frame hole in floor pan?Any ideas what to use for tape? painted masking tape? black gorilla tape? thanks John ???
BlackoutSteve
Got more info on the hole you are referring to? Pics?
Restoring my RHD 69 Jane in Melbourne, Australia.
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
Quote from: BlackoutSteve on April 18, 2011, 05:17:09 AM
This is what John is asking about and Quanta sells marking kits which have the tape or you can purchase it by itself. Others like heartbeat sell it also I'm pretty sure. JohnZ wrote some time back that he thought the tape was used to tape off the #3 hole for the water test..... I have the tape and will report back the size, etc...
john302
I think the tape covers the holes in the floor pan .That picture does not look correct. The reason they used the tape is for the water test???thanks John
Fisher Body used a piece of tape over both of the #3 body mount holes in the floor pan to seal them for their water test, before the body was delivered to the Chevrolet side of the plant; I don't recall what type of tape they used.
68Zproject
Are you talking about where the sub frame bolts go into the body?
68Z28
john302
Hello, yes the rear hole in the floor pan ,below the seat. thanks John
Quote from: john302 on April 18, 2011, 08:00:47 PM
The tape is 3/4" wide and is very different in black texture. Not like any other tape I could tell you to go get. I mentioned in my post what John had mentioned some time back concerning the tape being used for covering the hole for the water test. The picture is of what comes in the Quanta kit is is listed as "Technical Bullentin #69".
m22mike
Here is the tape John Z is talking about and was to cover the hole for water test. To my knowledge 1st. gen Camaros did not have any mounts taped to the frame. Note the sticky side is up. I think it is 2" and the OE's I have seen are black. I have used masking tape and rattle canned it with black lacquer with good results. AMK carries the black tape. I even scrounged up a roll at Carlise last year.
A 67
A 69
X66 L78 M22 4.10 Deluxe Threads, PNT 10/10, Red Hockey stripe
68Zproject
Quote from: m22mike on April 19, 2011, 07:29:19 PM
Mine had tape that went around like it held them to the frame for placing the body on when I took the originals off.
68Z28
m22mike
Quote from: m22mike on April 19, 2011, 10:04:58 PM
Any chance it had both ?
That's a distinct possibility - Corvettes had all eight cushions taped to the frame, and so did some passenger cars; if problems were encountered with cushions coming off at Body Drop, Production would start taping them until the issue was resolved - it was an ugly repair, or a line-stop issue.
68Zproject
I don't recall any tape on my plugs, but I do have my originals in a box and remember the tape around the sides when I replaced them.
68Z28
Charley
It looks like Gaffers tape. I have a roll I will dig out and get a pic.
www.1970Z28Camaro.com
www.MCACN.com
BlackoutSteve
I see there is a pic there labelled as a 69.. (Thanks M22Mike) ..but the 69 AIM (UPC 1-D1) makes no mention of the tape in it's illustration or components list.
Are we sure it's also a 69 detail?  :)
Also Charley, Isn't Gaffer tape the same woven cloth tape that is often used to tape down audio cables temporarily at events and such? (I think originally produced by Nashua)
The tape in the pics doesn't appear to be that same tape. It looks more like a very wide version of the same paper-type tape used to retain some of the single wires to wiring looms in the car.
