D90 Stripes
Started by redge, March 24, 2011, 06:22:28 PM
redge
Hi , does anyone knows if all 69 camaro SS with D90 stripes have exactly the same stripes or if only the early one « october 68 and november 68»have the stripe on the fender extension  ?????
All produced through early November 1968 have about 1" of strping on the fender extension. After that time the stripe terminates at the seam.
IZRSSS
If this information was misleading, please let me know...
This car has had one repaint and the stripe was duplicated exactly the way it was applied from the factory. It is a 12A build...first wk of Dec. 68. You can see the 1" overlap.
It is also my understanding the fender portion of the stripe was applied w/paint & the door portion with a sticker.
rat pack
Correct, fender stripes are painted, doors are decals...........RatPack..................
Man I love that Carolina Blue with white top and interior!!!
IZRSSS
#4
Thanks for the kind words Rat Pac.
You tossed me a bone with no meat...details on the pic please. Owner, Options, trim tag, POP, build date, plant, etc...If you'd like please send me a PM.
Let me back track just a little bit...the hockey strip was painted the way the person believed it would have been painted/or applied from the factory. Hence the 1" overlap on the fender extension for an early built 69. In addition to special paint, the car is also believed to be stripe delete. don't ask me why, even if it is I think I'll hang on to it. Just trying to make sure it was applied correctly.
rat pack
Even with special paint the car should have gotten the stripes unless you have docs to prove otherwise. I have never seen a Carolina Blue Camaro that was an SS that didn't have the stripes no matter what year.
The car above is an original RS/SS 396/325hp with a TH400, ps, pdb, D80, console, and the ZL2 air induction hood. As of 15 years ago it still had 90% of its original paint with only the vinyl top being removed, and someone "touching up" the small scratches with Testors model car spray paint to keep it from rusting. The owner that has it now tried to start restoring it about 10 years ago but gave up. Instead he installed another big block of unreal horsepower so he could have a "hot rod" play toy. One night while traveling down a back road he decided to see what it could do....his reflexes were not as quick as those of that big block. He got the car all crossed up and wrapped the left front fender around a small tree. So much for the original paint front fender! Luckily he did not have the original ZL2 hood on the car and that may have kept the damage from being worse than what it was. The driver's fender & headlamp assy, inner fender, grill, header panel, and lower valance were all that needed to be replaced. He didn't even bend the bumper! This car has/had its original D90 stripes on it along with the original fender pinstriping. The stripes did not go down onto the lower fender extension as they did on some earlier cars. Here is a picture of the firewall showing the crayon marking for "special paint", along with picture of the passenger fender. Look closely and you will see the factory pin striping. This car really needs to be restored, but I don't see it ever happening anytime in the near future as the owner will not spend the money to do it right..................RatPack...................
IZRSSS
Thank you for sharing some history on the car. Nice to finally see another Code 80 paint car {powder blue/azure blue} and an RS/SS BB to boot. Interesting information with regards to pin striping the outer lines of the hockey stripe on the fender. Very Cool!!! The crayon special paint marking is also very cool. Its just painful to see the car wasting away.
Do you know which plant it was built at...Van Nuys or Norwood? And...the build date? I would also like to see a pic of the trim tag if you have one handy.
Thanks again.
rat pack
I have done lots of research on finding the correct formula for the Carolina Blue that was used from 1967-1971 on all Chevrolet's. Pretty common color here in East Tn as I have seen it on everything except Corvettes, but I wouldn't rule out one being built.......... Trim tag info except body number:
TR  727           - E  PNT
      04C             X22
..............RatPack...........................
redge
IZRSSS
Quote from: rat pack on March 26, 2011, 08:40:13 PM
For those of you who have listen to this discussion before my deepest apologies!!!
RatPack, I only wish you could have weighed in a long time ago...don't ask. If I understand you correctly, are you saying there was actually a color developed under the name Carolina Blue in the mid 60's to early 70's that was used on GM cars? If this was the case, I would assume it had to be a paint line outside of what GM offered. None of GM's paint charts have the name Carolina Blue. Below is a chip for the 69. As you can see, the names are Powder Blue and Azure Blue. I had tried before to gather definitive information concerning Carolina Blue, but the only information I received was that NC fans are very hardcore with respect to athletics and painted everything in sight Carolina blue. Please share what you know about this color as it relates to GM cars.
Sorry Redge...
Nope, it's just a regional name for that color.
The Zone may have helped provide a color code to some dealers, but there's known to be several different shades of this color ordered.
And there's also Colorado Blue cars too.
IZRSSS
...Just a regional name...So NC's used Paint Code 80 on their cars but choose to call it Carolina Blue?
...Zone may have provided a color code to some dealers...?
...Several shades of this color ordered...?
...Colorado Blue...?
Sorry Kurt I just don't get it. Seems like a pretty tough way to nail down actual Paint Code 80 69's with so many variables... :)
lakeholme
Marty,
Here in Tarheel country (NC) we even think the sky is that color because of us!
Kurt and Rat Pack, have you ever seen a C80 Camaro that actually was sold by an NC dealer in that color?
IZRSSS
I am not all that familiar with NC Basketball but I believe they won their first National Championship in the 70's so it makes sense the name "Carolina Blue" as it relates to First Gens would have surfaced around this time. However, I am familiar with Lobo Basketball and it will be a cold day in H before we start referring to them as; Here in Albuquerque Monza Red Country... :-\
Charley
I had a LS6 Chevelle that color and I think the build sheet said something like Cadillac Blue A.L with a paint code. Somewhere I have a copy of the sheet.
www.1970Z28Camaro.com
www.MCACN.com
