Re-skinning Aluminum Distributor Housing
Started by 68ZRe, February 20, 2011, 05:20:56 PM
68ZRe
Hello.
Does anyone know who might re-skin a aluminum distributor housing
to get it back to the original finish after sand blasting?
What might the results be?
Thanks, Mike.
ss jim
Hi Mike,
Give CRG member Jerry Macneish a call at Camaro High Performance (z28camaro.com). I think he will be able to help you.  Jim
68ZRe
Dave69rag
Jerry took care a distributor for me last month.  I highly recomend his services.
David
Gramps69Z
Jerry also believes in taking care of the customer after the sale.
I highly recommend him for any parts or service.
Captain John Wykoff
I certainly wouldn't sand-blast an aluminum distributor housing; that's way overkill.
It could certainly require more attention than re-skinning if it was not "delicately" handled by the sandblaster. The turned OD where the numbers are stamped can be badly pitted by high pressure/and or coarse media.
Jerry@CHP
You do not want to use any kind of pressure blasting on these housings.  That's why we use a high tech tumbler.  It does not disturb the housing at all and keeps the original patina to the housing.
Here's a sample photo, we also clearance and set up the dist with a shorter curve and lighter spring.  This set up is worth HP on the dyno.
Jerry
9T4Z
this is what happens when someone blasts it..... :-*
Gary 9T4Z
69 Pace Car, 70RS,91Z,91RS
