68 idiot lights
Started by 68Zproject, February 20, 2011, 10:38:14 PM
68Zproject
What does the end look like originally for the green wire that goes to the temp sender on the head?  Pictures would really help.  I'm in the process of putting my gauge car back to idiot lights and have the end on the green wire for the gauge type temp sender.
68Z28
IZRSSS
I have no idea if the 68 idiot lights differ from the 69, or even if this pic will help, but here it is anyway. It probably isn't even the end you are inquiring about but maybe others will chime in...good luck.
68Zproject
Which end on the sender looks like the way it came from the factory?
68Z28
tmodel66
Sender # 01513321 is correct
Daniel
68Zproject
Thanks, I still have one of those.  I'll have to check and make sure it's the open or closed type though.
68Z28
68Zproject
Does the connector have the plastic end with a slot in it like the picture with the silver looking sender?
68Z28
tmodel66
Daniel
Quote from: tmodel66 on February 21, 2011, 09:59:53 PM
Only for a car with gauges - I think he's going back to idiot lights, which uses a "switch", not a variable-resistance (thermistor) sending unit.
Gramps69Z
My car with gauges and has that unit.  It's a 1969, but I don't think they changed.
Captain John Wykoff
tmodel66
Quote from: 68Zproject on February 20, 2011, 10:38:14 PM
I guess I should read a little slower so I can comprehend what the question is.  ::)  My bad !!
Daniel
flyingskibiker
My 68 with gauges uses 6400759 as called out in the AIM...  AIM says either 1993426 or 6488708 (opt.) for lights in 68.  Picture in the AIM shows a blade/spade type connector like the far right one in the above picture.
68Zproject
Quote from: JohnZ on February 22, 2011, 10:46:44 AM
As long as the end looks like 01513321.  I have one that looks like that and I will check to see if it works as "open"," closed".  The one Lectric Ltd. sells a s a "correct" one has a spade end on it and I didn't think that was the way they came originally.
68Z28
flyingskibiker
Quote from: flyingskibiker on February 22, 2011, 10:30:36 PM
From the other AIMs:
67 AIM:
1993369              Picture is of no help.  But no washer or nut.
6402666   (opt)
1513321   U17     No picture at all.
69 AIM:
6489356              Shows a pin type fitting.
1993369   (opt)    Wierd that it is now the option...
1513462   U17      Shows a washer and nut to hold on a ring.  Makes sense...
9T4Z
Quote from: WYKOFF69Z on February 22, 2011, 10:48:57 AM
The pic on the left is for the 'idiot light' I am very sure......
Gary 9T4Z
69 Pace Car, 70RS,91Z,91RS
68Zproject
Well, my AIM shows a spade connector for both the gauge and non-gauge connectors and I don't rally trust the AIM pics.  So anyone have an original idiot light 68 that can say what the end of the temp sender is supposed to look like for sure?  The research and info I came up with for getting the right gauge sender said, that one had a pin end and that's what the wire connector came with from AAW.  Does the idiot light sender have the flat knob end or a spade end?
68Z28
