rs rocker chrome trim
Started by craigsclone, December 21, 2010, 08:42:43 PM
craigsclone
i work at body shop.in prep we have 67 rs with 4 pieces trim along bottom.3 wide along bottom
of fender ,door and quarter and long thin one along rocker.i told guys i read here the car shouldn`t
orginally have all 4,each side that is.this one does..i know i read here in old ask articles that 3pcs. was the rs and others had the single rocker.what gives with this car you suppose?
  also does anyone have a colvins and could look up my casting numbers i posted on the decode
forum?no problem,just graduated h.s. last year saved up to get my 67 .can`t afford to buy books and parts .will hit flea markets this summer.                                    craig
Sauron327
67 RS had three wide moldings and the rocker spear for a total of 4 moldings per side. Just as the car in your shop.
craigsclone
sauron,
ok thanks,i have to buy lunch now !it did look orginal,however i had read here in the old ask crg before the forums i wrote it down.from sep.02,99 a peter imseis .someone i thought had said only one but not both.i had miss understood.mine only has the spear.thanks again.also seen a block that has almost same casting as my 327 3858180 it was fairly close.a 66-67 chevelle.the pistons are the ones i really would like to know about 3866954        craig
