D80 Rear Spoiler Dealer Install?
Started by Spicoli, November 07, 2010, 12:04:10 PM
Those rods look equal to me = not a D80 car.
Date is on the center rib of the lid.
IZRSSS
#16
I agree, the torsion bars look identical. It doesn't surprise me that it isn't a D80 car. If you recall J also mentioned it is a strip delete car. These two discoveries are consistant with a conservative look. I think this also raises a red flag on the front spoiler. It does not have the main frame anchor point.
The other dilemma I'm up against is the hood, its a repop. Was it possible to order a plain hood on a SS car? If it was I think Pat would have opted for this as well. Nothing on the car is consistant with what a guy would have ordered.
I could not find a stamp on the center rib/ribs of the lid. The paint was laid on pretty thick so maybe it's just covered up. Other than the stamp is there any other way to determine if its factory? Are all 1st gen lids interchangeable?
Just trying to piece these last few items together as best I can. Its been tough without the build sheet.
Thanks Kurt
Gramps69Z
Here's a picture of the rods on my D80 car.
Captain John Wykoff
The blue lid in the photo is the '69 "second design" lid - same one that's on my car; has the four holes in the inner panel to clear the attaching studs for the Firebird spoiler. Photo below is mine - the Fisher "run number" (date code) is directly below the jack instruction sticker, on the raised rib; you can't read it in the photo, but you can see it if you look closely. They moved it on the later 3rd design lid.
IZRSSS
#19
Quote from: WYKOFF69Z on November 12, 2010, 11:45:51 AM
There is obviously a visual distinction between the two. It certainly looks like the torsion rods are original to the car. If you look close, the spatter paint line would be hard to duplicate. No rear spoiler...what was this girl thinking ???!
Thanks for the pic John
IZRSSS
Quote from: JohnZ on November 12, 2010, 11:56:42 AM
I see it on my lid now... unfortunately there is so much paint that the stamp looks like a blur. I didn't know there were three different designs, thanks! Can you tell me which of the three is correct for a 12A Van Nuys build? Not sure if it really matters where it was built...?
Thanks John
Quote from: IZRSSS on November 12, 2010, 12:14:39 PM
Thanks John
It appears that the 2nd-design deck lid was used between about November '68 to April '69.
IZRSSS
Thanks again John. That's what I was hoping to here.
Dave69x33
My 1969 05A Norwood Camaro appears to have the 2nd design (with the four holes in the inner panel). The inner panel is stamped "T A10" in raised rib, to right of the jack instructions, and "A10" in a second spot along the middle bottom of the raised rib.
If I recall correctly, the T is the stamping plant, and stamping plant codes are typically H, K and T.  Has it been determined which plants these codes stood for?
The "A10" stands for the 10th week of 1969 which would be the week of March 10th, correct?
Quote from: Dave69x33 on November 16, 2010, 10:18:40 PM
The “A10” stands for the 10th week of 1969 which would be the week of March 10th, correct?
That's the "third design" deck lid (date code relocated, no weld tabs on the rear hem flange); it was used from about March to the end of the model year. I don't think the plant codes have been decoded, except for Kalamazoo ("K").
Dave69x33
And what does the "A" stand for in "T A10"?
L78 steve
Quote from: JohnZ on November 17, 2010, 11:26:46 AM
Weld tabs?
69 Z/28 Dover White. SOLD
Quote from: L78 steve on November 19, 2010, 09:22:10 AMThat's the "third design" deck lid (date code relocated, no weld tabs on the rear hem flange); it was used from about March to the end of the model year.
<<Weld tabs?>>
Yes - see photo below; the second design '69 deck lid had eight of them across the rear edge.
L78 steve
Does anyone know how to decode the dates? My trunk lid has a T  A44.
mark x22
