67' Speedometer cable firewall hole question
Started by Brandan, July 23, 2010, 09:04:50 AM
Brandan
From what I can understand the '67 automatic and Saginaw both used the same firewall hole for the speedometer cable is that right?  I have a pic of my firewall and want to double check.
Check out the 1969 ride!!!
http://www.cardomain.com/ride/676916/1
Check out the new project!!!
http://www.cardomain.com/ride/2960049
Quote from: Brandan on July 23, 2010, 09:04:50 AM
That's correct - every transmission except the Muncie used that speedo cable hole.
Brandan
Do you know the correct length for the automatic T350 speedometer cable?  I also believe that it routes under the frame kind of like the parking brake cable and turns toward the center of the car.  I want to say that the length is aroun 69 inches.... but not sure....
thanks
Brandan
Now I read an archived post that the short cable was used 28".  Now I am more confused.  I think the AIM shows the cable goes around the bottom of the chassis (like the parking brake), so I would think that the longer (69") cable would be correct.  Any help on this one.  Also where can I get one?
The speedo cable routing is shown in your Assembly Manual in UPC 12, sheet A3. The TH350 wasn't available in 1967 - don't know which cable length is correct for it.
Brandan
Thanks John, you wouldn't know the length of the powerglide cable would you?  I have checked everywhere I can think of........ ???
Brandan
QuoteAssembly Manual in UPC 12, sheet A3
thanks John, close but i found it on C3.  Looks like the manual and auto are the same??? ???
big iron
The 28" cable is for cruise control K30 option. UPC K30 A3  #7- 3919007.
Bob
Brandan
I am coming up with either a 58 inch or a 69 inch cable, at least narrowed it down somewhat.  Still not sure which one is correct.  I looked at all the parts dealers and with so many different cables it is easy to get confused.  Also Bob thanks for the post.  Unfortunately I don't have cruise.
Brandan-
rod396
Quote from: JohnZ on July 23, 2010, 09:59:39 AM
This is my 1st post, and I have been reading the comments on the speedo cable.................
I have a '68 RS/SS 396 with the Muncie 4 speed. Rolling bare body shell. I have noted the speedometer cable hole per the AIM for the big block,(under wiper motor) but I have no reference to the exact correct length of the cable. Does anybody have any info on this??
