67 z/28 waterpump casting number
Started by Ron C., November 29, 2009, 08:06:16 PM
Ron C.
The casting number that is on the 302 waterpump should be 3858326 or 3998207, is that correct? Thats what in jerrys book but I have seen more 3859326 pumps. I was just wondering which would be correct for mid year 67 Z28s.
67Z/28,67RSZ/28,71SS454CHEVELLE.
Ron,
The 326 pump is the one to use.
-Jon
jonboy1216
which one is correct for a april built 68 z28?
Quote from: 1968RSZ28 on December 01, 2009, 04:45:33 PM
Quote from: jonboy1216 on December 01, 2009, 04:31:54 PM
3859326 like this one...
http://cgi.ebay.com/ebaymotors/67-68-69-CAMARO-WATER-PUMP-FOR-A-302-Z28_W0QQitemZ250539757171QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3a55554e73
That photo very cleverly doesn't show the most important part of the 326 water pump - the tapped hole in the boss on top for the bypass fitting. Original passenger car 326's had a 1/2" NPT hole for the fitting, but the overwhelming majority of 326 pumps were made for truck applications, and used a larger 3/4" NPT hole. Commercial rebuilders convert most small-hole 326 pumps to 3/4" NPT (since the biggest volume for them is for trucks, not cars), which ruins their originality value for cars, since you have to use a reducer bushing, which results in a deduction in judging. Beware any auction for a 326 pump that doesn't show the size of the bypass hole (especially when the auctiion says "no returns accepted" like that one does).
Quote from: JohnZ on December 02, 2009, 10:35:19 AM
John -
Jerry MacNeish's "The Definitive 1967-1968 Camaro Z/28 Fact Book" states that the water pump installed on all 1967 and 1968 Z/28 engines had two slightly different designs; one with a 1/2" NPT bybass hole and one with a 3/4" NPT bypass hole.
I emailed the seller about the bypass hole on this water pump.  Here is his response...
Hi,
Yes it does have the bypass hole, it is 3/4 in.
- ziggy-777
