loosening the power steering pump
Started by my124677n, September 27, 2009, 07:28:01 PM
my124677n
This should be an easy one, but on my '67 small block with power steering (no a/c), I loosened the one bolt on the power steering pump (within the slide area) which I thought would allow me to push the pump toward the center of the engine (so that I could remove the belt), but it will only budge a small amount. Still too much tension to remove the belt. Any other bolts that need to be removed or loosened.  Thanks.
You also need to loosen the bolt that the p/s pump pivots on.
sixt9x33rs
If you dont have one you may want to buy yourself a Chasis Service Manual and also a Assembly Instruction Manual. Not trying to be a smart a. These manuals are a great help.
Have fun!
'69 RS Z/28 65B, 711 Flat hood no spoiler, endura, 4:10 44K miles (Sold)
Oregonjam
Just a tip for re-installation.
I use a strap wrench to help get a grip on the pump when tightening the belt when I am by myself. It won't scratch the housing. I have seen a lot of the pumps bashed in on one side from someone using a pry bar. This works well on the 1st gen small blocks.
68 07D SS350
John
