Aftermarket Guages in 68 Auto
Started by Oregonjam, August 28, 2009, 08:53:40 AM
Which of the options would be preffered on a 1968 Column Auto?
Install Guages with black after market bracket under ash tray
2 (40%)
Install 1967 wood grain guage bracket with guages under ash tray
1 (20%)
Keep original with no guages (dummy lights only)
2 (40%)
Total Members Voted: 5
Voting closed: September 27, 2009, 08:53:40 AM
Oregonjam
This is for a 1968 SS350 with auto column shift, no guages and the wood grain finish on instrument panel. Suggestions welcome.
68 07D SS350
John
hotrod68
I like the way Yenko did it--a single chrome panel below the ashtray with oil, amp, and temp gauges. It's simple and the gauges are easily readable. My 2 cents.
tom
Not sure what was in a 68 firebird, 69 firebird had a set of quad guages in the dash where a tach would normally go. I like the set, it might work in a 68 Camaro dash. Verify first.
69 X11 Z21 L14 glide
o
lakeholme
John,
Beyond originality, am I correct that your ash tray is woodgrain with an 07D build?
The continuity would help the "look"...
Oregonjam
Quote from: lakeholme on September 02, 2009, 07:48:20 AM
Yes, the center dash area is wood grain and all of the interior is a stock appearance. I do currently run Oil and Water temp guages on a black after market bracket using existing screws under the ashtray. I debated taking them out but am feeling uneasy about not having them for long hauls etc. I was also thinking that the continuity offered by the 67 insruments would be nice and appear stock to those that don't know. I think they will blend more with the deisgners intent of what the interior should be like. Although the feature was not on this Camaro I am considering adding it. The black bracket says to all that this is an after market addon and stands out.
I do go back and forth on it...
68 07D SS350
John
lakeholme
John,
Not sure I made my point clear:  I guess I would vote for your second option above, a woodgrain bracket, because it would be a consistent look with your 07D build.  My 68 12D build has the original black ashtray with the woodgrain panel.  (Beyond that, it has a console, so if I ever add guages, my choice is simple.)
Read through this thread (if you haven't already):
http://www.camaros.org/forum/index.php?topic=1534.0;all
I know what you mean about going back and forth on the decision...
lakeholme
Got your PM.
From Ed and others observations in that thread, your ash tray should be woodgrain.  It's first quarter 68 build dates that may go either way.
Oregonjam
Thanks phillip. I did not realize that black ash trays were used with the wood grain center dash sections early on. Thanks again for the thread and feed back.
68 07D SS350
John
