Gas tank date codes
Started by Dave69x33, July 04, 2009, 06:44:54 PM
jk1969z28
Here's another 06A car but is one of the last built June cars, vin 6647XX.  Tank numbers 69 45, picture attached.
Jerry K.
Quote from: rare4k on July 25, 2009, 12:41:02 PM
I justed went into my shed and pulled out the one i picked up for my 67 car the date on the tank is 52 N 6  get a pic for you all so there has to be a couple for the 67 aswell
Where on the tank was it stamped?
Thanks!
Buddy
I would like to know myself, still haven't found mine. Pictures would be very nice. ;D
Thx
Buddy
sixt9x33rs
Kurt,
I agree with you, I think mine was replaced too. Based on the dates. I guess the dealer smeared the undercoating on the tank?
Lawrence
Dave69x33
The code is stamped on the front RH (driver's side) corner flange of the tank.  You will need to remove any paint or rust to expose the date code.
Good Luck.
sixt9x33rs
Quote from: Dave69x33 on August 02, 2009, 01:06:44 PM
The RH side of the car is the passenger side, and the LH side is the driver's side; RH and LH are as viewed from the driver's position. :-)
camaro cat
I finally took the time to to check the other tank I have access too. It is an 11D date code and the tank has a 69 51 stamped on it. I notice others have one upside down number on their tanks. It could be that the 5 and the 1 were installed backwards and should have been 69 15 which lines up better with other submitted info. On my 02D car I always thought the 29 69 meant the 29th day of 1969 which fits with a 02D build date. But that is obviously not right. My guess is it refers to the 29th week of gas tank production for 1969 production and probably started at the end of July or beginning of August 1968.
Loren
Loren
1967 RS L30 10C LOS
1969 SS/RS L78 02D NOR
Dave69x33
Sorry...yes, it's the "LH" or "driver's" side of the tank.
red69
My 12C 69 has a tank date code of 16 69
302V8
Just checked my 1968 z28 03c norwood and it is stamped on left front flange witch a 68  34    hope this helps
Big_Al
I just got the date code off my 04A Norwood '69: 33 69.
The number seems to fit well with previous reports.
Al
'67 RS 327 convertible, '69 RS 350 coupe, '73 Type LT 350 coupe split bumper.
1968 Z28
My 1968 - 07C is dated 68 52
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
12D  68 20
02C  68 27
03C  68 34
05D  68 44
07C  68 52
07D  68 52
07D  68 53
09B   1 69
10A   6 69
10D  10 69
10D  10 69
11D  14 69
11D  15 69  (stamped 69 51)
12A  16 69
12C  16 69
01B  21 69
01C  22 69
02D  28 69
02D  29 69
02D  29 69
03D  45 69 - replaced?
04A  33 69
04C  37 69
04C  37 69
05A  37 69
05E  41 69
06A  42 69
06A  45 69
10A   9 70
crobjones2
Kurt
Another 06A with 45 69
I will see if my neighbor still has his original tank
Chris
69 SS 350
