Engine VIN location
Started by silver69z22, April 23, 2009, 11:08:01 AM
silver69z22
Hi Guys.
  My 69 RS has the partial vin # and suffix code on the front of the engine block behind the altirnator. The build date is 12-B 1968 and the vin # is 124379L513112. some research says it should be by the oil filter, not so on my car. Just wanted to share the info. have a good day,
steve
The location bounced around at LA. http://www.camaros.org/drivetrain.shtml#partialVINs
But your location is common for that timeframe.
What's the work order # on the cowl tag (e.g. A123, on the same line as the build date)?
What's the engine code?
Thanks!
Bdblu
My Z28 is a 12B build as well, I found the casting# and casting date but had a difficult time finding the vin.  I can vouch for not finding it near the oil filter.  I the only numbers I found there were foundry numbers.  Was your car a Norwood or LA car?
silver69z22
Hey Kurt,
   the work order number is L 7 1 7   the engine code is V 1 I 3 0 F L   it's the 327ci   210hp  hey Bdblu my car is from the Van Nuys, Ca plant or L A   thanks for replies, steve
XRAM
Does the same hold true for Norwood cars (1969 that are 1968 build) that are 12B - VIN could be at either the pad or filter location? What about 12A cars?
No. NOR and LOS processes did not change at the same time.
XRAM
Hi Kurt
Where would a 12A Norwood built VIN be - on the front pad or oil filter area?
It normally should be on the pad.
