side mirrors
Started by Oaklyss, October 18, 2005, 09:20:57 PM
Oaklyss
Has anyone found a way to keep outer door mirrors from moving? I have to adjust mine alot. It will move just from the wind. Thanks.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
69 4 Speed
Behind the glass, there are 2 phillips screws that you use can use to increase the preasure on the pivot ball.  Problem is getting the glass out without breaking it.   I almost had the glass out of mine when it broke in 2 pieces.   Cost me $20 to have a piece of smoked mirror cut to size but it doesn't flop around any more.   Don't know of a trick to fix any other way.  Maybe someone out there has a quick fix.      J.R.
mikeyparts
I JUST PU A LITTLE CLEAR SILICONE IN THE BALL SOCKET AND ADJUSTED THE MIRROR BEFORE IT DRIED
WIPE OFF EXCESS
69 4 Speed
Mikey.,..wish that i'd known that before I spent $20 for a new glass.  If the driver side ever goes south, I'll give it a try.
J.R.
roper
I have been trying to figure out a way to do that for the last five years, I am on my way outside right now to do the silicone thing hope it works. I was thinking along the lines of clear fingernail polish but couldnt get the nerve to do it. thanks for a great idea! roper
Blue Loctite on the ball also works.
roper
hey guys, just tried the clear silicone on the side mirrors, wont stand up to the car wash. I will try the blue loctite and see how that works. actually the silicone made it worse than before,after it got wet it was very loose! If the loctite wont work I may try to take a small punch and scuff up the ball a little to give it some friction. I will let you know how this works out.
69 4 Speed
I've scuffed up a lot of things with vice grips....but not always intentionally.    ;)  J.R.
roper
the small puch did the trick, stays put at high speeds, just lay them on a wooden bench and have someone hold them while you use the punch and go all around the ball of the mirror,Roper
Oaklyss
I used a combination of the replies posted here. I first scuffed up the swivel ball ( only where it wont show when adjusted) using my electric engraver tool, then put on blue locktite.
So far it seems to work fine, have not tested at 100mph yet. I will let you know. Thanks everyone!
lakeholme
#10
Has scuffing up the ball --without using locktite-- continued to work? ???
I tried the silicone and it gave way eventually even without the car wash. ::)
My concern is using the locktite and then later needing to adjust the mirror.
roper
#11
yeah the punch did the trick! It has been up to 100mph and did not budge. sorry it took so long to reply. I havent been on line for quite some time. my car is a convertible with the original top so as you may have guessed the back window has tarnished to the point that you can not use it so I depend soley on the side mirrorrs. Its pretty nice now that they stay put when someone closes the door and I dont have to readjust the mirror.
