DZ 302 186 heads
Started by Lukes 69 z28, April 06, 2008, 11:53:20 PM
Flowjoe
Quote from: JohnZ on May 16, 2008, 05:54:43 PM
... Also, Saginaw/Flint blocks had a 1/8" NPT square-head plug in the front of the block, just above about 11 o'clock on the timing cover; Tonawanda blocks didn't have the hole or the plug. Photo below.
any reason why?  Wouldn't corporate GM use one mold design across all corporate entities for standardization?
melav8r
#16
Definitely. The year portion of the casting date code on a Tonawanda block is two digits, and it's only one digit on a Saginaw casting (like C 3 9 on a Saginaw block, which would be C 3 69 on a Tonawanda block. Also, Saginaw/Flint blocks had a 1/8" NPT square-head plug in the front of the block, just above about 11 o'clock on the timing cover; Tonawanda blocks didn't have the hole or the plug...
Does that apply to Small Blocks, specifically trying to identify any differences between a Tonawanda cast small block and a Flint Casting.
Quote from: Flowjoe on May 16, 2008, 10:37:01 PM
The block machining process differed slightly between Flint and Tonawanda; although both sets of tooling were installed in 1954, Flint modified theirs for what they considered to be a more reliable method of creating an intersection in the front oil gallery by gun-drilling that hole from the outside and then plugging it. Tonawanda elected to stay with the base design and create the intersection from the inside; this difference remained all the way through the production run of the Gen I block.
If you find a block with a single digit for the year in the casting date and the plug in the front, it's a Flint block; if the year is two digits and there's no plug, it's a Tonawanda block.
melav8r
JohnZ, What about a '68-'69 SBC with a single digit for the year, possibly no front plug, but stamped with a Tonawanda assembly-date/engine-i.d. stamp? Until I confirm the front plug, is there a possibility Flint blocks were shipped to and assembled in Tonawanda?
Both plants had dedicated foundries nearby, so generally no blocks were exchanged between them. But exceptions could occur.
Post or email me a pic of the pad and I'll take a look.
Flowjoe
Quote from: JohnZ on May 17, 2008, 12:56:09 PM
that's very interesting to know - thanks John.  It does still stun me that corporate would allow that much discretion on such a key component and not adopt (or require) one or the other as "best practice".
Best practice?? Back then, the plants and the divisions were all competitive. There was no company-wide vision. They didn't see the freight train coming.....
melav8r
Quote from: KurtS on May 17, 2008, 11:02:23 PM
Heres the link, seller just informed me no front plug so with the stamp and JohnZ's info it's definitely a Tonawanda block, but it has a single digit for the year.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190222656104&ssPageName=ADME:X:RTQ:MOTORS:1123
crobjones2
I have to concur with melav8r - my 350  2388 block is dated E209 - there is no plug
It is only a single year digit- could this be a difference for Tonawanda between 68 and 69?
Chris
69 SS 350
I think John may be incorrect on that detail. (gasp!) I don't recall ever seeing a 67-69 block with two digits for the year in the cast date.
I'm not positive about the 2-digit year code after '67 (my Corvette focus is '57-'67, and the 2-digit year code was the Tonawanda small-block discriminator during those years); Tonawanda big-block casting date codes used a single digit for the year. They may have changed the small-block date code format during and after 1967.
melav8r
Quote from: JohnZ on May 20, 2008, 09:28:10 AM
Thanks for the info JohnZ, apparently the "T" blocks also use a single digit year code for model year '69, whether cast in 68 or 69, but I concur on the missing front plug. here's a T on the face of another "T" block in the area behind the timing chain. I wonder if that identifies it as a Tonawanda casting?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=260242701219&ssPageName=ADME:X:AAQ:MOTORS:1123
Quote from: melav8r on May 21, 2008, 08:30:34 PMhere's a T on the face of another "T" block in the area behind the timing chain. I wonder if that identifies it as a Tonawanda casting?
Several of the other pattern identifiers have a "T" as well, so it's probably a Tonawanda casting - can't tell from the photos if it has the front plug or not.
jmcbeth
Quote from: Lukes 69 z28 on April 16, 2008, 09:42:16 PM
Thanks for the help everyone,but I would still like to talk to someone who has a car that is dated close to mine.
Luke,
If you still need someone with a date close yours, please reply. Mine is 09C. Last digits of Vin are 685955.
John
1969 Camaro Z/28 RS
Numbers Matching
I'm a little late on this thread, but my original unrestored Z28/RS is also an '09C' build week.  I'd love to see some comparatiive information for similar cars.   I'm also in the need of a set of correctly dated '186 heads', as when I bought my car, one head was damaged (a stud had pulled out and been welded back! ).   when I rebuilt the engine in 1977, I sold those heads and bought an almost new set of 'angle plug' heads - which were very hot at the time - for less money then rebuilding the ones I had!  (good deal then, bad for restoration!).  *G*  My engine date is also late August..  so I've been looking for mid-August 1969 dated heads.   I've several sets of '186 heads for ealrier in '69, and also from '70 yr for trade if anyone has date-compatible ones to trade.  Luke and John:  I'd love to compare data with you.  I'm attempting my first image attachment herein, but I don't know if it is going to work.
PS.  Re the relationship of casting to assembly dates:   My '69 302 in my camaro was cast one day prior to assembly.   I've got an original '57 Bel Air (283) which was cast/assembled on the same day (which I've always thought was amazing!)..
