406 small block
Started by nlpirr, February 27, 2006, 05:25:01 PM
nlpirr
Okay..I have yet to actually id my engine to verify that I was told it is a 406 small block? I had no idea Chevy even made a 406 small block or maybe the seller is blowing smoke up my exhaust?
Can anyone help here?  How can really identify my engine? Is there a master data base I can find that will match block id numbers?
thanks for the help..
Nick P.
lakeholme
I'll let the CRG members give you the low down on decoding, but you might want to go to the decoding button on this site and start with the flollowing link:
http://www.camaros.org/numbers.shtml
I can tell you that the 406 does exist.  The following link is an article from Chevy High Performance about a 406 build up.
http://www.chevyhiperformance.com/techarticles/148_0306_406/
The siamesed-bore 400 small-block was used in many Chevrolets, but was never used in a 1st-Gen Camaro; it didn't become available in full-size passenger cars until 1970. a "406" is a 400 with a .030" overbore.
lakeholme
#3
As always, John is right.  It is not an original first generation Camaro motor.  What you have, however, is a potentially great "street racing" machine.  The great thing about a small block 406 is that it has "street manners" (torque, rpms, etc.) but it is really a racing motor (depending on how it is set up... may have 600+ hp).
What else can you tell us about it???
Here is another article about the 406: http://www.carcraft.com/techarticles/68999/
By the way, THE decoding book for first generation Camaros is: Chevrolet by the Numbers: The Essential Chevrolet Parts Reference, 1965-1969 Alan L. Colvin.  By what John said above (no 406 until 1970) it may not help you much on the motor, but it is a wealth of info. about the rest of your car.  There is a 1970-75 edition.
nlpirr
Thanks for the info on the 406 and the "potential" in this engine. I did read several article thanks to your direction on the "406" and it seems to have been a great replacement and beef up to old 1st gen. engines on theri last legs??
more on engine, it has a ton of power it seems and I'm trying to get this engine optomized to run as smooth and efficient as possible. I put on an electronic choke on the holly carb. 4 bbl and it has a Elderbrock victor Jr. Intake manifold.
I  had it timed, and I replaced the oil. plugs, ect..  I think I really need to beef up the starter? the car runs well ( I think) and has a bit of smoke at start up that disspears. the exhaust/fumes seems a bit " strong" and the engine idles pretty well and does not bang, but I have no idea what to compare it to? in other words, is it running as it should or not?
I have a rebuild TH350,  373 geared posi, flowmaster exhausts and a 2800 stall converter.
So the big question I have is what can i do to get this engine up to par without killing the pocket book so fast??
thanks for the help again !
