Recommendations on how to repair carb stud
Started by Flowjoe, January 07, 2008, 07:41:16 PM
Flowjoe
I have a GM high rise Aluminum intake (3972110 - '70 LT-1) it has one bent carb stud...what is the best way to repair or replace this stud?
thanks
Jerry@CHP
Double nut the stud and remove it.  If there are no threads left and the stud is broken, then you'll have to use a pair of vise grips.  If it's tight, then heat will have to be used.  Good luck.
Jerry
Flowjoe
Thanks Jerry.
So it is threaded in and not pressed in?  I was afraid it was a press in and figured replacement might be as for press in rocker studs.
It has threads left so I should be able to double nut it.
Quote from: Flowjoe on January 08, 2008, 09:47:15 AM
Thanks Jerry.
Yup, it has ordinary 5/16"-18 threads on the manifold end of the studs.
