302 Z28 Divorced Choke Rod Adjustment
Started by COPOZ/28, January 27, 2024, 07:01:05 PM
COPOZ/28
The '69 Chevrolet Service Manual provides information on how to adjust the divorced choke rod on Z28 302's (and other Holley 4 barrel equipped V8 engines) on pages 6M-3 and 6M-7.  As written, the procedure is unclear.  On page 6M-3 it says:
    "On all engines except L6 and 2 barrel V-8 engines, hold the choke valve closed and push the rod downward to contact stop -- the top of the rod should be even with the bottom of the hole in the choke lever.  On L6 and 2 barrel engines, hold the choke valve closed and pull rod upward to end of travel.  The bottom of the rod should be even with the the top of the hole in choke lever."
There is no specific reference to Holley 4 barrel equipped engines in the 6M-3 page write up.  Therefore, should the choke rod be adjusted (bent) in the same manner as the above description for the L6 and 2 barrel engines, so that the bottom of the rod is even with the top of the hole in the lever?  I ask this because the 302 choke rod operates similarly to the L6 and 2 barrel engines -- namely, the choke rod is pulled upwards to hit the end of its travel.
Then, on page 6M-7 it says:
    "With Rochester 4MV and Holley Carburetors, install the choke rod and adjust as necessary.  Be sure choke valve moves freely from full open to full closed position."
I assume the instruction on page 6M-7 refers to the procedure on page 6M-3 which, unfortunately, does not mention Holley 4 barrel equipped engines.
Is the L6 and 2 barrel V8 procedure the correct choke adjustment procedure others have used on faithfully restored 302's that results in clean starts when the throttle is pumped just once to set the choke, without having to pump the throttle multiple times, before turning the key to start the engine?
If anyone can shed more light on this maintenance/adjustment procedure for 302 z28's , I would be very grateful.
Chuck B.
Ice cream run in our unrestored '69 Z/28 on Woodward Ave. in Royal Oak, MI.
Daytona Yellow, NOR 05E, Born on June 2, w/X33, M22 and 4.88 'BX' Axle via COPO 9511CB.
(Need Speedo Adapter p/n 6476736 - 0.777 ratio.  Have 6476735 - 0.824 ratio and 1565215 - 0.950 ratio to trade)
GMAD_Van Nuys
COPOZ/28
Thank you, GMAD_Van Nuys, for providing the link to the Holley 4150 repair/adjustment procedures -- very informative.  In reading through it, I noticed there are several carburetor adjustments that require a specific dimensional measurement be achieved for that feature to be adjusted properly.   There is a note in several places that state: "On some models, a specified dimension will be given in the specification table."  Is there a chance you might have this specification table for the 4150 carbs and be able to share it?
Chuck B.
GMAD_Van Nuys
Chuck - I found this information on adjusting the divorced choke rod on a Holley 4150 carburetor:
https://books.google.com/books?id=_fTHcnYMyywC&pg=PA76&lpg=PA76&dq=adjust+the+divorced+choke+rod+on+holley+4150+carburetor&source=bl&ots=XIvAO1nn5m&sig=ACfU3U1UwnGZbSdSAebvVwdZPv4yrBAOsQ&hl=en&sa=X&ved=2ahUKEwiWuuymopqEAxXPI0QIHT4mBaE4ChDoAXoECAMQAw#v=onepage&q=adjust%20the%20divorced%20choke%20rod%20on%20holley%204150%20carburetor&f=false
In the Ford 1970 Car Shop Manual, there is a procedure for the Holley Model 4150-C 4-V Carburetor on page 23-06-02 "Choke plate clearance and fast idle cam adjustment."
1.  Remove the choke thermostatic housing cap.
2.  Place the choke plate in the fully closed position by opening the throttle level to about 1/3 throttle, and press down on the front side of the choke plate.  While holding the choke plate closed, release the throttle lever.
3.  With the choke plate in the closed position, measure the distance between the flat of the fast idle cam and the choke housing mounting post.  If the setting is not to specification, straighten or bend the choke rod to obtain the specified clearance.
4.  Bend a 0.036 wire at a 90 degree angle approximately 1/16 to 1/8 inch from one end.  Insert the bent end between the lower edge of the piston slot and the upper edge of the slot in the choke housing.  Open the throttle lever to about 1/3 throttle and rotate the choke lever counter-clockwise so the bent end of the wire is held in the housing slot by the piston slot with light pressure applied to the choke lever.  Measure the distance between the air horn and the down side of the choke plate.  If the setting is not to specification, bend the choke lever to obtain the specified clearance.
