Hole in trunk pan for 1969 camaro for fuel sending unit
Started by hdptsr, June 09, 2023, 06:45:19 PM
hdptsr
Hello,
I had to replace my trunk pan, and am now installing the fuel tank and sender.  I realized I did not take note of where the sending unit comes through the trunk pan.  Does anyone have a picture and measurements where this hole for the tan wire should be drilled.  What is the whole size?  Also where does the ground wire attach?  Thanks for your help.
169INDY
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
hdptsr
Do you have any pictures or measurements where to drill the hole?
169INDY
You can scale it appx & double check your sender grommet before final drilling.
1969 LOS Vert.
Others can double check
68 Z28 M21 LOS
Badshifter
The ground wire attaches here, on the doubler that the tank straps attach to.
1969 Z28 X77 09C
Edgemontvillage
#5
Alternate View - Location of Sending Unit Ground
169INDY
Lloyd do you have a "After" photo?
It is a 'loaded question, I want to discuss the "Electrical Terminal" used Originally and on GM service parts and repop / aftermarkets.
68 Z28 M21 LOS
Edgemontvillage
Quote from: 169INDY on June 16, 2023, 12:03:24 AM
Jim, I'll assume this is what you meant. The original, factory installed fuel sending unit ground wire terminal has a squared off end and an integrated washer in the center which is unseen when the grounding screw is attached (per the photo in Reply #5). The GM service replacement (non-reproduction) ground wire terminal is oval and does not have an integrated washer. For Legends judging the GM service replacement sending unit is accepted without a points deduction providing a star washer is added and is visible. In the photo below I have not added the star washer.
Original fuel sending unit ground wire terminal with integrated washer
GM Service Replacement sending unit ground wire and terminal (star washer not added)
169INDY
68 Z28 M21 LOS
