Preservation of a 68 Camaro
Started by cook_dw, December 01, 2021, 08:09:31 AM
Here was my solution since I liked the Yenko placement but did not want to drill or mount it to the dash:
But, that is if you changed your mind about it being on the column.
On a separate note, for getting deeper scratches out of glass, have you ever wet sanded them with a really fine grit of sand paper? I was going to try this, but I was curious if anyone had success doing so.
Previously removed the steering column for clean up and turns out the lower bearing was trash so it'll get a disassembly, clean and new lower and since they do not sell the bearing for the upper and since it is staked into the aluminum housing it would be a possible issue but thankfully the upper bearing on mine was good just needed repacking with grease.  Lower bearing was ordered from Ground Up (ss396.com).
Photo 613 - 616 - column removed and disassembled  and of the column decal
Photos 617 - 620 - Paint markings on inner tube etc.
Photos 624 - 626 - Main shaft cont.
Photos 627 - 629 - Tolerance ring & spring before and after
Photos 630 - 632 - Lower bearing compared to new replacement
Photos 635 - 637 - Upper bearing before and after cleaning
Photos 638 - 639 - Mid cup after cleaning but before evapo
Photos 640 - 641 - Lower cup after cleaning but before evapo
Photos 644 - 646 - Inner tube after soaking
