69 Temp sender with threads wire mounting sequence
Started by camaronut, December 01, 2022, 11:49:55 AM
camaronut
Ok....I've tried everywhere to get a picture of an original car with the temp sender wiring with console gauges.
I have a kit from HBC that has TWO nuts and the star washer.  I see on the AIM that the wire terminal is put in first, then the star washer - then the nut - then tighten.  Ok - easy.
Am I to believe that I should have one nut tightened onto the sender, then the wire terminal - then star washer - then the other nut and tighten that all together??????
I'm going with the AIM - but are there any original cars out there with two nuts?
Looking for the real experts to chime in!!!!!  LOL!
x66 714
My car is factory with gauges & still has the original sender. 1 nut, 1 lock washer. Not a star washer. With the original sender, there's not enough threads for a 2nd nut.....Joe
camaronut
x66 714
camaronut
Interesting - I looked in the AIM and the part number for that washer is 138479 - which is a "toothed" washer.  Looked it up on AMK and internet search, and its a toothed washer.  Could this be another GM AIM vs reality snafu?  I just found a picture with a cross ram that has what you have - a split lock washer.
Whatever - I have better things to worry about.  LOL
x66 714
I've had that car since 1981. I always put hardware back where it came off. Between 1970, when the dealer finally sold it & 1981 something could've changed. I wonder what others have on their cars?....Joe
camaronut
Kelley W King
Not doubting Joe,s car came with a lock washer I think that the star washer is what was intended and should be there.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Agreed, star washers were designed for electrical conductivity....
camaronut
I decided to use the star washer like is says in the AIM.   Would be nice to see other original cars...
perryrj
Isn't this the original style sending unit for a 69 with console gauges?
x66 714
No. That the replacement that some companies sell.
I'm most likely going to change mine to a star washer. What Kurt says makes complete sense.....Joe
Quote from: perryrj on December 13, 2022, 11:49:47 PM
IIRC, that's the style without gauges.
x66 714
I just did some research on the 138479. I didn't find it in AMK. On GMWikisearch, it says it's a #10 external star washer with a 13/32 o.d., zinc. It's the same lock washer that's used on the starter solenoid & probably many other places. Sorry for the confusion....Joe
169INDY
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
