1969 Original Battery Cables
Started by ban617, January 27, 2020, 03:56:32 PM
ban617
  Hi , my project car still has it's original battery cables spring type for a top post battery , are the clamps available to crimp on the original cables ?
Thanks Rob
They do not sell the ends if I understand your question correctly.
169INDY
I have this exact same problem.
I have a few Orig 68/69 Cables,  yet the Spring Ring Clamp ends or the #10 feeders are damaged. When I reached out to Lectic Limited for inquiry they WILL NOT service any original components due to Liability and any negative effect to sales of their restoration line products.
Now if you GM Orig Factory Cable that  just has a damaged Round Ring Spade terminal you can source replacements via Digi-Key or Newark electronics, sizing the Barrel to the proper gage and the Ring hole to the proper size for the stud on the solenoid. Crimp, Solder, Insulate.
A lot of cars judged are not negatively affected by using Factory Fit style replacements ? I think ?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
