1968 spark plug heat shields
Started by x66 714, April 04, 2022, 05:19:57 PM
x66 714
Are these correct for a 1968? Thank you, Joe
mgreenz
Yes, they appear to be same as the ones on our "survivor" 68 LOS car.
I believe that the spot welded ones belong in the passenger side.
___
Terry
Look good Joe and yes mrgreenz correct as two piece on drivers side.
x66 714
Thank you both. Putting parts aways for the car's future....Joe
bowtie68iho
The brackets and mounting bolts on the two-piece side are painted Chevrolet orange.  The two spot-welded brackets are not painted orange.   If you look at the 68 AIM, it indicates that the two-piece brackets and their mounting bolts were already attached to the engine when the engine was painted.  Maybe you should paint the brackets and mounting bolts orange before you store them away for the future so you don't forget later?
Bernie
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
bowtie68iho
Just to clarify, the shields on both sides are not painted, neither are the small screws holding the shields onto the two-piece brackets...just the two-piece brackets and their respective mounting bolts.
Bernie
x66 714
x66 714
These pictures support Bernie's post about LH brackets being painted. That would mean they were on the engine when it left Flint. That being said would also say that the 2 bolt for those 2 bracket & the 2 installed at the assm line could be the same design but most likely didn't have the same head markings. That would explain why I have 2 & 3 bolts of the same design with different head markings...Joe
I took this picture recently of Skip's 69Z 21K mile survivor reviewing and confirming that the screw and bottom section of spark plug 2 piece heat shield (drivers side) that bolts to block was installed prior to paint at Flint and bolt's captured washer was in fact a star type locking washer.
x66 714
