68 Camaro Database
Started by toddmitchell734, February 08, 2022, 06:55:50 PM
toddmitchell734
Is 124378N434851 in the database, I'm looking at the car to buy.  Thanks
Nope. Sorry. What's it being advertised as?
toddmitchell734
It's advertising as just a 68 Camaro, but the 15" tire sticker in the glove box looked very original and the interior looked like it had never been restored or messed with
Share photos and get opinions.  Don't make the mistake of buying a car and it turning out to be not what you hoped..
QuoteIt's advertising as just a 68 Camaro, but the 15" tire sticker in the glove box looked very original and the interior looked like it had never been restored or messed with
Well, glove boxes are easily changed so that really proves nothing. And the type of interior doesn't tell you anything either so if you're looking to buy and curious as to what the car is, post pictures like Darrell stated.
adjudimo
Quote from: cook_dw on February 08, 2022, 07:57:51 PM
X2
And what else other than tire decal in glove box has you wondering?
toddmitchell734
The 12 bolt had a code of BS, with 4 leaves  and the radiator tag was UH
You're going to need to post pictures of the axle stamp and the date code on the center section. Also, 4 leafs isn't definitive proof of a Z28. 4 leaf springs were used on non-Z28's as well. The UH radiator was also used on the base V8 327 engine, so again, no definite proof, especially since I believe these are being reproduced.
Post a picture of the engine pad too. Make sure you remove any paint with paint remover and DON'T use anything abrasive. If it's the original engine, that'll tell you exactly what you have.
Quote from: toddmitchell734 on February 10, 2022, 08:44:47 PM
A 3.31 axle is not likely to be under a 68 Z28.
x55cam
Is the radiator a 3 core?
Be careful about reading  health books. Some fine day you'll die of a misprint. - Markus Herz
