124379N613490 X22 Cowl Tag is it original or for entertainment purposes only
Started by 69RALLYSPORTZ28, November 13, 2021, 08:15:01 PM
69RALLYSPORTZ28
124379N613490 is for sale online and advertised as a Super Sport although the original engine is no longer in the car.
Aside from the rivets that are obviously wrong and the lack of black paint, does the Cowl Tag look to be original?
In my opinion it is a real tag. The VIN fits the 02D tag date. But the non-OE rivets indicate it was removed. Get a pic of the VIN tag.
CantRepeat
-Tim
The trim tag was the first part produced for the dealer order. At some point it was attached to the body during fabrication, prior to any coatings. The [blind] rivets were installed with a device that expanded and ruptured them. They were filled with seam sealer to prevent engine bay fumes from leaking into the ventilation system.
The firewall was not extensively primed; I have never seen primer on a body tag. One of the last body fabrication steps was firewall blackout, a skim coat of satin black paint. This usually included the entire tag although it is not unusual to see little to no paint at the top. Also not unusual to see light body color overspray across the top.
There are a few exceptions to this. Some '67 tags were masked during firewall blackout, no paint at all. Some were painted white after installation, then masked. A very few early '68 tags were painted white off the car, then installed and masked.
Excellent question!
BillOhio
So if you see the center of the rivet it should be pierced if factory?
1969 Z28s, Burgundy and Rally Green
1968 RS 327 4 speed
1970 Z28 M22 4:10
1969 RS legend certified
