What the low down on this vin # really looking for about when it was built.
Started by IVEGOTALL3, March 10, 2021, 04:47:33 PM
IVEGOTALL3
Hi Camaro Lovers, Could someone guide me on or about the time this Camaro was built? Vin # 12439N604551  have the body data I just would like to confirm it matches the VIN.
1969 SS 396 Camaro:1968 Butternut Camaro:1967 RS Granada Gold Camaro:1955 Chevy Truck X 2:1964 GMC SWB 4X4 Wide Side:1968 C-10 LWB Fleet side:1969 C-10 SWB Fleet Side:1972 C-10 SWB Fleet Side X 2
N604551 would have been final-assembled on or about Feb 25. Should have 02D tag date.
IVEGOTALL3
 :) This is what the Cowl tag shows'.  Thanks for the detective work.
QuoteThis is what the Cowl tag shows'.  Thanks for the detective work.
Sure. As long as it's a factory tag! A lot are not.
And by the way, you're missing a digit in your VIN. It should be 124379N604551
IVEGOTALL3
I didn't want to make the detective work too easy.  The vin tag and cowl tag appears to be original from what I have noticed, but what do I know.
IVEGOTALL3
Here is what I have.  From what I have found it appears to be an L34 car.
Kelley W King
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
IVEGOTALL3
I think the original running gear has been swapped out, here is a couple pics of the rear-end numbers.  I haven't researched it much.
IVEGOTALL3
I guess its below the u bolt. I'll have to get the car on a lift to pull it off, I'm way too big to climb under and unbolt it.
