kick panel
Started by mdz, December 30, 2020, 10:45:37 AM
mdz
Looking at my kick panel the cotton pad glued to the back side , is that for noise or  thermal insulation? Was thinking of using some carpet padding as mine is in poor shape. Also has anyone replaced the gasket in the flapper doors, tried a search but nothing came up.they pop right out ,finding the rubber gasket might be hard.
Petes L48
Is that seal a foam pad riveted to the flapper doors?  If so, the vendors carry that as a kit with rivets, "kick panel door seals"  My car has AC, and some of those systems seals are a rubber perimeter seal bonded to the steel doors.
https://www.rickscamaros.com/catalogsearch/result/?&q=kick%20panel%20door
Some have the thick felt kick panel backing as well.  Looks like you could replicate that easily for less $$$
https://www.heartbeatcitycamaro.com/store/product/16171/67-68-69-Camaro-%26-Firebird-Kick-Panel-Insulation-Pair/
mdz
Thanks Pete for the help, I checked 2 different catalogs but found nothing. I know no one will ever see the ones I restore, but I'll feel better, thanks again.
169INDY
Quote from: mdz on December 30, 2020, 10:45:37 AMAlso has anyone replaced the gasket in the flapper doors, tried a search but nothing came up.they pop right out ,finding the rubber gasket might be hard.
Yes, Look in My Build Thread for some photos of the process.
Page #7 Reply #101
http://www.camaros.org/forum/index.php?topic=15748.90
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
mdz
Nice job on those doors Jim, working on mine right now. Snow coming down here real good.
169INDY
Once you figure out the Semi-Tubular Riveting process, It can be utilized for Proper restoration of many parts on the Camaro that used this form of joining of materials. Personally I hate pop rivets used where incorrect even if not seen, AIM, UPC 0 A5 for 1968
Raining in the Seattle area, but that said it could be any month but Aug, 11 other months require Gray sky's and wet stuff. PNW liquid sunshine. You can keep the Rain you must Shovel. :) Grins!
as far as the Kick Panel Door for 69 the Repop push pull cable actuators are Cr@p, Difficult to make work as my Buddie Dan found out.
68 Z28 M21 LOS
