4053 Carb adjustments
Started by x66 714, March 20, 2020, 02:54:56 PM
x66 714
In front of the choke housing where the 4053 number is located there are 2 screws that have something to do with air. Is there an adjustment for these 2 screws when this carb is used on a 302? Thank you, Joe
Usually 1.5 turns out from fully in.  I was told and shown how to do this when I was about 10 years old.
You can tune better using a vacuum gauge.
Good video here
https://www.youtube.com/watch?v=xscWLSpB5Go
x66 714
Thanks Bryon. The carb needed some serious work. Stuff that I couldn't do here including some re-machining.
You're not referring to the fuel mixture screws...right?..Joe
I added the video link after you posted. I wasn't trying to be sarcastic, even if it may have seemed so.  I was working on cars at a very early age.
x66 714
I watched the video. That carb doesn't have those screws...Joe
Post a pic of the area you are talking about, please.
x66 714
If you're referring to this (see below), I believe those are machining plugs, not screws.
x66 714
 There are screws under those plugs. They appear to be some of the problems according to the carb builder....Joe
Sorry for the mix-up.  I thought you were talking about the idle mixture screws.
I am not aware of what those screws do, if anything. The holes above the screws are normally filled with junk.  A lot of carbs don't even have the holes machined into the housing.
Jerry@CHP
Those are the bleeder screws and they are set by Holley when the carbs are built.  You should never have to go in there.  I don't have to fool with these on my Stock Eliminator '67 Z28 race car either.  If someone monkeyed with them, they may have to set and recalibrated.  Have you checked everything else out on the carb?  Warpage, correct jetting, dirt in the carb, etc.
Jerry
x66 714
Typically there is a little white lithium grease smeared in the hole...
Here is the original carb from my old Z and then after Eric at Vintage Musclecar restored it.
Eric does fantastic work.  I just finished rebuilding an original 3837 for the 67 Chevelle I'm doing.  Was able to keep the original finish to match the car.
