Repair / strengthen cracked plastic on cluster 68 camaro
Started by sabino56, December 13, 2019, 06:43:50 PM
sabino56
68 Camaro speedo/ gas instrument panel
The plastic is cracked around the screw holes at bottom and a crack is starting up towards bezels.
I'd like to prevent the crack from running and strength around the screw holes.
Wondering if anyone else has been through this and had success.
I was  thinking of trying JB weld on backside bridging crack.
Any suggestions on epoxies or glue for this plastic or suggestions would be appreciated!
77thor
Hmmmm... I would use fiberglass resin mesh on the backside.
1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B LOS Build
1977 Camaro, 350(LM1), M20, 10 Bolt Posi, Purchased New, (SOLD)
sabino56
Thanks for suggestion.  Looking at it a bit more, I think I can make a sheet metal backing plate and either epoxy or fiberglass it in.  I'll post whatever I do and succeed/ fail when I do.
I repaired a lot of 69 dashes including rebuilding screw bosses. I use J-B Weld. If you do anything threaded, coat the screw in oil first and put it in place, then put the epoxy around it. The screw can easily be removed after epoxy sets.
adjudimo
You should also drill as small of a hole where the crack ends. This will stop the crack from getting longer. Then fill the small hole in when you repair. I would use JB Weld to do this or you could let the fiberglass resin fill it in. Your choice. But definitely drill the hole. It works.
sabino56
I first attempted a repair on a '69 dash back in '76 when the wiper switch mounting pegs broke off. IMHO repairing them is just kicking the can down the road. No matter how well engineered the repair is, they usually fail again. In particular, the mounting tabs for the cover at the base of the steering column. It's 50 year old plastic. There are excellent repros of the 69 dash cluster and if you're going through the bother of removing it, best to do it only once.
'69 dash pads, same deal. Over time, the pad shrinks and the plastic liner cracks and warps. You can glue them back together but it will be temporary.
Kelley W King
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
I've had success with JB Weld and screen door mesh. On contoured areas I use the plastic screen. Have also fixed wiper switch bosses on 69s
ZLP955
I repaired my '69 console base pretty easily with JB Weld but am going to get a plastic welding kit and try that method out on some old parts that are beyond saving. The kit I've been looking at consists of what resembles an electric soldering iron, and plastic filler rods of different thickness and base plastic type (ABS etc); rods come in black, white and grey.
Tim in Australia.
joesauer
I repaired mine with JB weld, but over time cracks appeared elsewhere.....just an age think I guess.   Eventually, just replace the housing.  Not that expensive.
sabino56
Just update on what I did.  I decided to try to save the cluster for now until I decide what I do on interior. Interior is not bad & I didn't want a new shiny cluster with everything else aged.
I formed some 18gage sheet metal pieces to fit the back side of bottom of cluster and JB welded it in place.  I'm not great with metal forming so it was kinda fiddly to get it to fit without stress on plastic but it worked out ok.  The metal backing makes it stiffer and allowed me to mosaic back the broken pieces to reform the screw holes. We'll see if it lasts or just causes cracking to move elsewhere.
