CE Block crankshaft and piston
Started by Terry69RSZ28, December 15, 2019, 09:27:34 PM
Terry69RSZ28
Hi,
Are these correct for 1969 Z28 CE warranty block? It is standard bore, the pistons have no numbers and the crankshaft has one notch.
Thanks, Terry
Yup, that's an 1178 crank by the notch, the piston number is cast on the underside of the piston (under the dome). Should be L2210A, TRW.
Terry69RSZ28
Hi Everyone,
Without taking the engine apart, does the photo showing the top of the piston point towards an original piece? This block does have the correct 1178 crank. Thanks, Steve for the verification.
169INDY
Here are shots from my Z28 CE motor (Installed in a 68) Casting March 1969
Photo of crank hub and piston top.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Terry69RSZ28
Hi Jim,
The photos you provided look identical to the two I posted. My CE is a late 69 date code block. Thanks for posting.  :)
The 1178 crank mandates the use of the L2210A piston (or any other manufacturer's 302 piston) due to the pin location required when using the 3.00" stroke crank with the standard 5.7" C-C rod length. You also know that this is a late '68 to '69 era 302 piston - 67-early 68 used a different appearing dome arrangement, very distinctive, you can tell at a glance what years they fit. Early pistons were also press-fit pins rather than the floating pin arrangements for the later (2nd design) pistons like you see here.
Terry69RSZ28
Thanks for the information, Steve! Always learn something new...
Regards, Terry
