1969 Camaro Big Block-Is it legit?
Started by tommygun280, August 04, 2007, 09:37:17 PM
tommygun280
Hi, I'm looking at purchasing a a 1969 Camaro RS SS396 350hp Auto A/C RS/SS 396 Camaro and have been trying to validate the originality of the car (always a challenge). I would love some input. Here are some key facts:
The trim tag reads st69 12437 nor 312029
729 52E
O5A x22
Carb# is7029204 FFand does not have a date code
Block 3955272 cast D-22-9 (2 days before the front pad date)
Front Pad has T0424JI (codes out to 396 350hp)
Owner states in writing the partial VIN # is on the lower part of the block
Intake date code is H 8 8 (pretty early?)
Turbo 400 #'s are either ct-68 0r QT-68 (I think this is incorrect ???)
Rear end code is BM (correct for 3.31 open)
Original 2 piece brake rotors
Curved neck radiator
Thank you!
9T4Z
Hi
Might be good idea to post the vin also...
I am aware of two 05A cowl tags and the body numbers are are like 7 to 10 thousand higher... so a little odd...
but I am just a curious onlooker here and the other guys will chime in soon enough to help out...
good luck
Gary 9T4Z
69 Pace Car, 70RS,91Z,91RS
tommygun280
Jonesy
With all the fake tags out there, it would help if you posted a pic of the tag. Also a pic of the engine block pad stamping.
1969 Z28 Azure Turquoise
I'll ask the same questions I asked on TC:
Does the car have AC?
What is the rest of the axle code?
Do you have a pic of the cowl tag or engine pad?
tommygun280
The car does have A/C.  I've asked the owner for a picture of the cowl tag and the stamping on the front of the block but no response so far...I should have taken them when I went to see the car.
