396 oil gauge line routing and fittings
Started by DeanZ10, August 07, 2019, 03:10:41 PM
DeanZ10
Posted this under originality with no responses, so thought I would try here. Thx for your help if you can.
I see this was discussed back in 2016 but with seemingly no final conclusions. Does anyone have a pic of the original set up for the L35? Looking at the aim page 416.  Should it utilize the bracket #8? Is the line shown between that bracket and elbow #5 a metal sleeve with the nylon/plastic hose routed inside or is metal portion carry oil??  Thx for revisiting the subject.
Dean
What year L35? My 67 has the nylon line from the block fitting to the gauge.  The metal pipe from the block fitting to the bracket was later...not sure what year though.
DeanZ10
Thanks for the response. It is a 69 model.
Dean
camaro cat
I'll see if I can help you out. I have an original bracket & bolt (#3954228 & 3817006) that goes on the head, NOS nylon & steel line (#3954225), and original brass fittings (#444052 & 444030) that screw into the block. Mine is for an L78 but all except possibly the fitting that screws into the block above oil filter should be the same for all BB. I was trying to find the original rubber grommet (#3906193) that the nylon line uses to pass through the firewall but am not sure which drawer it is in. I'll see if I can find it and even if not I'll post pictures of what items you want to see.
Let me know if you want photos of all or some.
Loren
Loren
1967 RS L30 10C LOS
1969 SS/RS L78 02D NOR
camaro cat
I'll add a little more. I miss posted the part numbers I have. It looks to me that the nylon line #3921433 is used on both SB & BB, even though they source oil pressure in distinctly different areas on the 2 engines. On the BB, after going to the left side of the engine where bracket #3954228 attaches, the remaining distance down to above the oil filer is filled by the steel line likely because the engine heat there would be too high for the nylon line to survive very long.
Loren
Loren
1967 RS L30 10C LOS
DeanZ10
Loren
Thank you very much for your assistant. Yes, love to have any pics you can send. By chance do you have one of it installed?
Thank you
Dean
camaro cat
No, unfortunately for posterity, my car is still all in pieces but I think the pictures should tell you what you need to know. I need to bring the line in the house and take it all apart and photo each part as best I can with all markings and such. I'll try and accomplish that in the next day or two.
Loren
Loren
1967 RS L30 10C LOS
DeanZ10
Thanks and please take a pic prior to taking it apart if you would.
Dean
x66 714
DeanZ10
Funny when you see something and just have to say.duhhh. Lol. Makes perfect sense to me now. Thank you Joe!
Hopefully Loren's pics will duplicate this.
Thx
Again
Dean
x66 714
No problem Dean. as you can see my engine is out of the car. I just kept forgetting to take a picture. Fighting time. The car is being painted so I'm trying to do everything else before it comes back...Joe
camaro cat
Joe, this brings up a question I had when I received my bracket and bolt that attaches to the head and hold the top end of the steel oil line. My bracket is also painted chevy orange but since those parts are listed in the AIM, meaning they were installed at Norwood or Los Angeles, long after the engine was painted in Tonawanda, shouldn't they be an unpainted bracket? I'd like to hear what those who have seen this say.
Loren
Loren
1967 RS L30 10C LOS
x66 714
I'm sure it wasn't supposed to be orange. Most likely not painted or black. Not sure myself. That is what I did in 1982 maybe. I will correct it...Joe
x66 714
I removed the bracket yesterday & found no evidence of paint on the back side....Joe
HawkX66
Sorry for the late reply... Here's a couple of pics to add that I hope will help.
U17 Oil pressure line fittings by Dave H, on Flickr
U17 Oil Fitting by Dave H, on Flickr
20141122_094528 by Dave H, on Flickr
U17 Oil Fitting L34 by Dave H, on Flickr
firewall pic by Dave H, on Flickr
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
