1969 broardsheet codes 5AO14A and 5Z11AA ?
Started by wono427, June 12, 2019, 08:30:20 PM
ZLP955
Body number (from the trim tag) would be unique to a LOS-built car, or do you mean a firewall crayon sequence number, often 3 digits?
Tim in Australia.
The 'crayon marking' as the body moves thru the plant is generally referred to as 'sequence number'... as in my Camaro has '18' on the LHS shoulder (under the fender)...
Quote from: ZLP955 on June 22, 2019, 11:18:04 PM
Not for 1969. Both plants were on the same order entry system.
ZLP955
Quote from: william on June 24, 2019, 01:53:21 PM
Yep that didn't come across as intended; what I meant was that LOS production ended well before NOR production saw the body numbers reset around the (anticipated) end of model year, and so there couldn't be 2 LOS '69 Camaros with the same body number, unlike NOR.
Tim in Australia.
wono427
Hi I am referring to the one letter 3 numbers stamped
on the body tag , not the body VN number on the same tag
On The damaged broadsheet I have , the box before where the serial number would be looks to have the same 3 numbers but no letter
It very hard to see and am trying to get better photos
To post
Thanks for the help
Would that be the projected build week??
wono427
P165 is the stamping  on trim tag -build date is 24/4/1969 from NCRS
ZLP955
Tim in Australia.
P165 =    P represents the 21st of April (assuming April is the month the body was built);  The 21st of April is the 16th production day (corresponding to the P).    165th body to be built that day...   so body was built 3 days prior to final auto assembly completion day (24 April)...
if I did this right??   I don't normally see LOS cars in my area...
Quote from: wono427 on June 26, 2019, 01:47:51 AM
Approximately 16th day of production for the month.  165th body for the day.
You're right Bryon!~   :)
seems I can't count on my fingers!!  :)
I corrected my post...
It's ok Gary, I had to check and then re-check myself - twice!
In the Engine RPO box there is a single letter... should be a G.
G = 302
wono427
wono427
trying to read sequence numer box
