68 RPO D55 hole positions
Started by SS396, March 09, 2019, 04:29:55 AM
SS396
Does anybody know of a drawing showing the dimensions for drilling all the trans tunnel holes in the correct position? Putting in some new sheetmetal and want to get it right. Got the photo off this site to show all the holes I'm talking about.
x66 714
I'm sure the aftermarket panel doesn't include the dimples as described in the AIMs book....Joe
Spooky
I could make you a template of mine and send it to you if you want.
Scott
SS396
Yes Joe you're correct, no dimples in new sheetmetal. That would be great Scott, but I live in Australia so I'm not sure how we could make it happen.
x66 714
Quote from: SS396 on March 09, 2019, 07:01:40 PM
If you could get all the mounting dimension from the forward bracket, you could use the console as a guide for the rest of it...Joe
Spooky
I'll work on it tomorrow making dimensions and posting them up here. It probably will help others too.
Scott
SS396
Much appreciated Scott.
Regards Larry
Spooky
Hope this works, All measurements were taken from either the centerline of the tunnel or from the seam  where the cowl to floor meets (bottom of blue tape)
Scott
SS396
Thanks Scott, you've done a great job. As you said, I'm sure this will help others too because as was discussed there's no dimples in new sheet metal.
Regards Larry.
