Font Question
Started by Edgemontvillage, December 12, 2018, 02:05:33 AM
0424 on the rearend,,114-115. 04d(68) build date.
After soaking, one side was fine, the other faded, but legible. Painted with quantra white, inspection mark paint.looks good,,even being hid.
13
On the drums, if it means anything. I believe just part numbers on the cylinders.
Our 68 seemed to be 36 something so very late 1967 for our 01B car. It's still on as I cleaned carefully and used evaporust. Cleared it with satin lacquer to protect if I remember correctly.
Some simple and easily obtained paints to color match components I used.
Jano raised question about the brake cylinders....
Quote from: janobyte on December 14, 2018, 04:10:07 PM
.... I believe just part numbers on the cylinders.
I rebuilt my brake cylinders and have a photo of one of them, although I don't know the significance of the numbers.   Some of these numbers might be a date code??
The "7/8 5464 079" is the standard script for these so nothing to do with date code Gary.
Thanks Chick!  :)    Learning is what being here is all about....  :)
