RS Headlight Switch Testing/ Refurb
Started by clm69z28, August 24, 2018, 11:17:04 AM
clm69z28
Is there any way of testing the RS headlight switch to make sure that the dimmer and other circuits are intact? And is there any acceptable method of cleaning or refurbishing the switch? Thanks.
169INDY
Electrical Contact Cleaner Spray 5oz Aerosol Deoxit Metal Connector Cleaning
D- Series D5
This is a product I have used with success. I have also Un-crimped the zinc potmetal bodied hard case switches from 67/68 cars & kickdown with limited success. Disassembled, removed crusted grease and burnished (Polished sliding contacts) using craytex rubber abrasive stick (Heck a pencil eraser works also.)
Then just used an OHM meter to check continuity across terminals when closed & opened.
JIM
JIM
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
clm69z28
Thanks Jim, I will give the Deoxit and your suggestions a try.
Chris
