Smog Pump Spacer Usage
Started by ZLP955, May 19, 2018, 02:23:49 AM
ZLP955
Did any '69 models use a spacer between the smog pump pulley and the white fan, or did all pulleys bolt right up to the fan? I've seen the spacers used on Corvette and others, but so far, not on a first-gen. Thanks!
Tim in Australia.
ZLP955
Thanks Kurt, I read that report many times but didn't see any reference to spacers.
The bolts I bought to mount the pulley are too long and I wondered if a spacer was required. Looks like I need shorter bolts then.
Tim in Australia.
I have some original bolts, I try to find and measure them...
ZLP955
Tim in Australia.
x66 714
Hey Tim. Mine are 1/2" long & use lock washers. Let's see what Kurt says.....Joe
Short ones are indeed 1/2" length under the head (pictured), the longer ones fit the spacer equipped models (this particular spacer came
off a '68 dated pump). No '69 I have ever seem came with the spacer, this one came off a complete '68 assembly pump.
ZLP955
Thanks for the pictures - the bolts I bought are exactly like the loose one next to the spacer in Steve's photo - longer and with an unthreaded section of shank. Good to see the correct short ones, so at least I know what I need now.
Tim in Australia.
