1969 deluxe door panel window wipers
Started by x66 714, June 19, 2017, 02:19:02 AM
x66 714
Can I please see a direct end view? These almost look like re-pops. Thank you, Joe
JKZ27
I really am not sure what they are since I have no package. They were stuffed in a tube labeled for and containing the outer fuzzies. 36 11/16"- long on the chrome.
John
68 RS Ash/Ivy Gold 327EFI M20
68Zproject
Quote from: JKZ27 on June 23, 2017, 07:41:48 PM
What application are the outer fuzzies for?
68Z28
JKZ27
7729998 69 Camaro outer door fuzzies. Probably 68 and firebird as well.
John
68Zproject
68Z28
JKZ27
Quote from: JKZ27 on June 23, 2017, 08:20:17 PM
Quote from: 68Zproject on June 23, 2017, 10:37:41 PM
Deluxe or std?
My parts book doesn't specify deluxe or standard for the outers. It only says 68-69. They look like the outer fuzzies on my 69 with a standard interior.
John
x66 714
The outers are different on a 68 if it has style trim....Joe
Charley
Here is just one way to soften rubber that I found in Google search.
Rubber Softener
    Spray the rubber with silicone spray. This spray can be found at any camping supply store. Spray until the rubber is soaked. Place the rubber inside an airtight, plastic bag. Use large garbage bags for big pieces of rubber.
    Keep the rubber in the plastic bag for three to seven days.
    Lift the bagged piece of rubber and bend it to check for pliability. Once the desired suppleness is attained, you can remove it from the bag for use. You might need to repeat this process if the rubber hasn't softened to the extent you desire.
x66 714
That might be an idea. It's 120 degrees in my garage at the moment so nothing is getting done. Maybe a piece of pvc & a couple of caps would provide a tight seal....Joe
feastersss
Camaro Central now carries them, I replaced them on my door panels and looked really close to NOS...part# WEA-987.
'68 RS/SS BB L35 Convertible..., Born w/drive train, R1 paint,  red interior, 725 Deluxe interior, white power top
8N325767....Looking for POP
Do the pictures (on page 1)show the contrast between standard and deluxe interior? or are we not sure of the application?
I have a deluxe interior car now, and I can't tell what I am looking for here. thanks
68Zproject
I was told, (an old post I saw by JohnZ) that deluxe had flat chrome beads on felts on the door and standard had round chrome beads.
68Z28
JKZ27
Austin, those pictures are of currently unverified parts.
I found them in the tube with my 69 outer fuzzies. I thought deluxe because they don't match my standard ones. But, the truth is, I have no idea what they are now.
John
