1969 camaro radio antenna delete
Started by Olympic gold, January 23, 2017, 05:28:50 PM
Olympic gold
i would like to get rid of my unused radio antenna with out leaving a hole in the the fender. and not any body work or paint. i would even consider just replacing it with a retractable one. is there any products on the market to fix this.  Thanks
1971ls6
The factory used a plug to fill the hole, all fenders had the hole
69 Copo 12.28 @ 117.50 4spd on polyglas
71 LS6 vette 12.31@118 mph PSMCDR
QuoteThe factory used a plug to fill the hole, all fenders had the hole
Well, no. Only cars ordered with a radio (and without the RPO U73 rear antenna) got the hole in the front fender. The drilling instructions are in the AIM, UPC U63/U69, sheet B1, view A.
Quotei would like to get rid of my unused radio antenna with out leaving a hole in the the fender. and not any body work or paint. i would even consider just replacing it with a retractable one. is there any products on the market to fix this.  Thanks
If you don't want the hole, you'll need to either fill it, plug it or buy a new fender. But I'm confused. You want to "get rid of the antenna", but "replace it with a retractable one". Those statements are contradictory!
69 Zee
Quote from: Olympic gold on January 23, 2017, 05:28:50 PM
Sounds like you don't use or have a radio and you just want to plug up the hole without doing any bodywork... yes ?  Reason for suggesting a retractable antenna, then yes that's your best option w/o it looking botched.
Overall that just kinda seems odd though  ???
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
They have little chrome plugs for the fender hole.
Yep. Try searching for chrome antenna delete cap.
Olympic gold
sorry for the confusion but i just want something that looks better than my crooked 3 foot tall wobbly antenna. thanks for the suggestions
69 Zee
You can replace the mast ... simple,  if your wanting it to remain cosmetically correct.
Darrell
