69 RF brake lock up?
Started by Rufcar, November 19, 2016, 04:31:13 PM
If it's a factory backing plate, there will be an opening, but it may have a dust seal pressed into place...  The hole should be directly behind the adjuster wheel.  look for the rubber plug and remove it...
Rufcar
#46
Ok up date! Rear Right cyl. leaking. Replaced and cleaned. Brake shoes adjust internally there is NO seal, probably because its a 70 or 71 Nova rear! Who knew? I ran the serial number on the axel. Cleaned both sides. Adjusted by putting drum on and off using adjuster. Car stops perfectly now! YEA! Tkx for all your advice.
For the record here is my 400hp camaro
JKZ27
John
68 RS Ash/Ivy Gold 327EFI M20
Sauron327
I can only assume since one wheel cylinder was leaking the other is tired, as well as the rear flex line. if that collapses, your rears will lock up again.
Paint your grille surround orange the way it is supposed to be originally. If you so desire of course.
Rufcar
Sauron327 Tkx the other cyl is new. Not much stock on this car in many years. That's why I bought and built it the way I wanted, though I did use all GM parts that were available in 69. I built one similar in 1970 with same side exhaust. If it was original id keep it that way. Tkx
Rufcar
Here is the pic of the old metering valve and new plumbing. Tkx again for all the advice and what makes this forum great!  Merry xmas. Now off to finish up my 70 Chevelle project! Jim F
Rufcar
Took her out today around the property and it seems the RF is locking up again except I need to brake harder to do that. I think it may be the old metering valve I installed. I did clean it up and blow it out and it seems to work with 35lbs of air pressure. Your thoughts?
Look up the thread(s) on the site for the metering valve rebuild protocol. You can order the kit and rebuild it yourself, pretty simple and inexpensive procedure. Both proportioning and metering units should be up to snuff - you can do both -
Rufcar
HustleRussell
Seems like you're unsure which wheel is locking up? I'd get a helper to watch from outside of car to verify which wheel is locking.
Russ
68 RS
69 SS
Rufcar
HustleRussell
Hi Jim. In post #50. Is that some kind of adapter in master cylinder that the front line is screwed into?
Russ
68 RS
69 SS
Rufcar
Nope it's mstr cyl to metering valve. Then rear of metering valve to distribution block as per pic in crg factory pic.
Sauron327
Quote from: 1969Z27 on December 15, 2016, 07:28:15 PM
To me it looks like adapters used with incorrect lines. I've used them before in other applications when using universal brake lines. Complete adapter lines are also now available for repairs. Since all the correct pre-bent factory lines are available for these cars, there is no need for adapters. They don't affect the braking, they just do not look original.
Rufcar
Sauron, I agree. It,was all I had as I just wanted to see if the system worked.  Hopefully tomorrow my new meter valve Will be,here as I was not able to cancel the order.
