Help with Drive train numbers
Started by jim28607, September 06, 2016, 08:21:14 PM
jim28607
engine numbers any help decoding would be much appreciated
69 RS/SS BB 4 spd
68  RS/SS Convertable BB 4spd
It's either a 65 396 325 or a 69 427 335.
68 Ragtop
Looks like the small 6 cylinder manual trans with air conditioning code.
Assembled at the Tonawanda plant on November 27, 1966
Check it yourself here:
http://www.camaros.org/drivetrain.shtml#PadStamps
jim28607
Quote from: firstgenaddict on September 06, 2016, 08:43:00 PM
I just came up with the 427/335, was told it was 69-427
69 RS/SS BB 4 spd
Quote from: jim28607 on September 06, 2016, 08:21:14 PM
In order to find the correct application, you also need to supply the block casting number and the block casting date.
jim28607
Quote from: 68 Ragtop on September 06, 2016, 08:45:25 PM
Assembled at the Tonawanda plant on November 11, 1966
Yea I saw that too, but it is a BB, I found the 69- 427/335 or 65-396/325 on Camaro.com, was told it was 69-427
Thanks for your help.
69 RS/SS BB 4 spd
jim28607
Quote from: 1968RSZ28 on September 06, 2016, 08:53:13 PM
Thanks Paul, I am going to look at that .
69 RS/SS BB 4 spd
68 Ragtop
Quote from: jim28607 on September 06, 2016, 09:00:03 PM
Sorry for the mis information, but it would have helped if you said it was a big block!
JKZ27
CBTN shows LB is a 1969 427 335 passenger, 3-4 speed. Possibly the 2bbl version?
John
68 RS Ash/Ivy Gold 327EFI M20
As stated earlier, we also need the block casting number and date.
Casting number will be on the back of the block, top side of the bellhousing flange area.
