Attaching Vinyl Top
Started by Daspots777, August 27, 2016, 12:43:17 PM
Daspots777
I'm having trouble locating the metal pegs/studs, whatever they're called, to attach the trim piece/keeper for my vinyl top. I am missing about half of them and can't seem to find anyone that has any. Thanks!
Eastwood (among others) sells the stud guns and trim rivets for attaching trim like the factory did with a welded stud. Used the same for window trim clips -
You can buy the rivets as replacements from them, and/or buy the whole system. Comparatively easy to handle - see the website link below that shows the stud detail (with the approximate clip in the pic).
http://www.eastwood.com/stud-welder-trim-rivet-tip.html
ban617
    If your car is already painted , you should be able to get ones that screw in just drill a small hole & screw them in ... Most body shop supply places have them or can get them ...
Daspots777
Excellent, that gives me somewhere to start.
Thanks to both of you!
69 Zee
Here's a previous thread by HawkX66 (Dave) another member.  Discussing the stud placements as well as a stud gun tip (home made).
http://www.camaros.org/forum/index.php?topic=13894.msg120737#msg120737
Also just for future reference, try using the search window at the bottom right of CRG's home page (showing the 3 Camaro's) as an overall search.  Or in the forum section each "Group Discussion Topic" will also have a search window at the top right.
Ex..discussion forum "Originality", type Vinyl top rivet
Hope this helps
'69 Z/28 RS Cortez silver/black with endura bumper, U46 option
'69 Z/28, X77 Dusk Blue, white top, all orig, under restoration
'70 Plymouth Superbird, Limelight green, 45K miles
