1969 Special Paint Car
Started by HOT3O2, July 28, 2016, 06:08:39 PM
HOT3O2
Does anyone know how many special paint (--) Camaros there were in 69, And if so how many were stripe delete compared to non standard color (Paint).  Thanks
Rick
69 RS/Z28
Based on our small sampling, 1.5% were designated special paint.
In addition to stripe delete and non-rpo paint color there was non-standard stripe color. Three Z/28s are known; one of them does not have - - paint code but is noted on the w/s.
http://www.camaros.org/exterior.shtml#ColorPercentages
fsc66
Closer to half of that......
Paul Winvoices......
HOT3O2
Thanks for the info. William what colors were the non standard stripes?
Rick
69 RS/Z28
Here is one of those special stripe colored car's tag
HOT3O2
Quote from: ko-lek-tor on July 29, 2016, 06:41:16 PM
Do you know the car because you can't tell from the trim tag. What was the stripe color?
Rick
69 RS/Z28
Quote from: Hot302 on July 29, 2016, 05:10:03 PM
Stripes were generally black or white based on a chart in the ordering info. Some combinations changed with a vinyl top or convertible; some did not. Fathom Green always had white stripes. Rallye Green had white stripes with no vinyl; black stripes with a black vinyl top.
The chart was either revised later or had errors. It shows black as the default stripe color for Le Mans Blue; in production striping was white unless the car had a black top. Burgundy is shown with red striping with or without black top; a few early production cars were built that way including one Z/28. Later Burgundy cars always had white striping.  Also, I believe there is a black car or two built with red D90 striping.
Known non-standard Z/28 striping, all on non-vinyl top cars: Hugger Orange/Black, Le Mans Blue/Black, Cortez Silver/White. I am aware of a Daytona Yellow/Parchment Z/28 with white stripes; wasn't built that way.
This raises another question: How was stripe color determined on special color Z/28s?
I thought if the tag was coded for special paint, that meant "see instructions".
Quote from: Hot302 on July 29, 2016, 08:18:00 PM
I can't say I really can swear to knowing this car , but I will. Why? I have owned the car since 79 in its original paint. KurtS. said that was probably the reason, after viewing the car's pictures, for the special paint since nothing else is out of place or unusual. Car is Black top white stripe FROM this site 71  LeMans Blue      Copy/paste in bold and notation is in header of table : W(4)With no V.top white stripe ,  B= w/black top-black stripe, W =Ivory top-white stripe  http://www.camaros.org/numbers.shtml#ExteriorColors
My car (-B) Ordered 71 with black top and white stripe. This car has been submitted for this same topic a couple of years ago when the question arose, and probably several other places on this site. Thanks.
HOT3O2
Thanks William, Great information I wasn't aware of.
Rick
69 RS/Z28
HOT3O2
Quote from: ko-lek-tor on July 29, 2016, 10:19:50 PM
Where was your car built? I too have a (- B) car that I have owned since 76. It was a LA  built car and the only reason I know it was a stripe delete car is it was printed on the build sheet I pulled of the top of the gas tank. I appreciate you sharing the info on your car.
Rick
69 RS/Z28
William-"This raises another question: How was stripe color determined on special color Z/28s?"
My take is that GM assigned default stripe colors as a means to simplify or determined the suggested color. A special colored car would not have a default, therefore, I think the customer ordering would have had to make that choice also along with the color or in some cases have the stripe deleted (on any model package that stripes were part of a package). Obviously, from documented cars, the customer had a say to over ride the default. I would think some dealers would discourage this as it made more work on their part and what about cars that were ordered one way, but came off the truck different than ordered?
Quote from: Hot302 on July 29, 2016, 10:50:31 PM
As tag shows, Norwood. Ignore the long haired punk (dent as bought)
HOT3O2
Quote from: ko-lek-tor on July 29, 2016, 10:57:52 PM
Reminds me of some of my old pictures back in the 70's.
Rick
69 RS/Z28
Rick, "Reminds me of some of my old pictures back in the 70's."
Should I be saying, Great, Good Vibrations & good times, glad I could take you back? or, Sorry about that awkward time and bad memories? LOLOL !! It was a time when I did not do anything, grooming wise or clothes wise, to get a gal, yet wanted one....but it was a GREAT time!!
