Unpublished: 1967 Z28 Detailed Production Numbers
Started by fsc66, July 07, 2016, 10:26:37 PM
fsc66
Total 1967 Z28 numbers show 602 Z28's produced for the production year. These numbers are further broken down by specific ECL codes:
BA  Standard Z28 configuration - 362 units
BB With Air Plenum - 174 units
BC With Exhaust Headers - 9 units
BD With Exhaust Headers and Air Plenum - 57 Units
Paul Winvoices
Seems like this info was previously known?
Is there any further breakdown of RS Z/28's
Or Z/28 by color?
I have seen the estimates, just not sure if there are hard numbers, thanks
Thanks Paul. Do you have similar data breakdowns for 1968? Thanks!
fsc66
I looked when you first posted to see if I could help with the RS Z28 data or the Z28 color breakdown. Unfortunately the data for that is not granular enough and there Is no usage data for the multitude of Z22 ECL codes with the exception of how may coupes and how many convertibles. As far as exterior paint, there is no breakdown for Z28 just a general breakdown of each color code for Camaros as a whole.
Are there any documented primer or special paint '67 Z's?
fsc66
Doug, there is a color category called "Special and Prime" but it's for all 67' Camaros, not specific to Z's.
Paul, where are you getting this breakdown information on the Z-28 ECL codes?
Paul, as Byron asked do you have the same breakdown for 68 Z/28's you had for the 67 Z/28. I would imagine the numbers for air cowl plenum and/or header orders would be fairly low.
fsc66
It's from an unpublished trend book that was shared only with a few GM Execs. I believe one of those Retired Execs last year sold a copy and now a few others have that information. Pretty sure NCRS has it all, but no one is sharing any of the information for the most part.
Yes I have that data for 68's', The 69 Camaro information is only through the end of August so it was not final data.
The Book encompasses all Chevrolet Models dating back to the mid 50's through 1969. There is limited 1970 information through only March.
The biggest issue is that often times the ECL codes are listed with individual production information but there is no usage column stating when that ECL code was used
As an example, 1968 Camaro under Z22  lists in parenthesis 108 ECL codes with 40,977 units produced. No listing of each ECL code. Under ZJ9 there's only 4 ECL codes, each is listed with production on each ECL but no explanation of when they are used. I think you understand.
What kind of insight does it provide for 69?
X33 , X77 , X11, X55 etc. production numbers?
Z/28 with RS option production totals?
fsc66
No, these were not options, so they are not listed. Their components would be listed.
Are you asking me again about Z28 RS combined data lol
Engines, trans and many engine trans combinations also. However sometimes they combine so you cannot calculate individual combinations.
As an example, 1968 Camaro 396: 325 & 350 HP show a total of 229 3-spds used between both of them so we don't know how mnay for each. However, sometimes when you look at the 3-Spd option code, it will have engine usage broken down further.
yes, I was hoping by 69 they may have broken down the information more...lol, sorry.
Paul, does it show the breakdown on engine usage between Coupes and Convertibles? For example, the 1968 L89. Does it show the number of Coupe vs Convertible applications? It's always been "assumed" that of the 272 L89 engines, approx 20 were installed in Convertibles and the rest in Coupes.
fsc66
Well, under L89 there is only 1 ECL code and it lists 272 Units. It states, used with L78 and L78 shows
4 ECL codes with no usage data.
