Hurst Shifter date codes
Started by JoeC, April 06, 2016, 03:10:12 PM
Quote from: cruizin69 on April 12, 2016, 08:29:42 AM
The date Code on my shifter is 19D51J from a 02A Z/28
LOS or NOR ???  If you can, try to make pic a little smaller next time.  Thanks!
jdv69z
So attached is a pic of the Hurst shifter from my 69 Z, build 10B, Oct 68. Shifter is dated  6  8B2. The 6 is hard to see. I'm not sure this one is on the list? Sorry if duplication.
Jimmy V.
Thanks Jimmy V. I had copied your data over from the shifter report thread earlier.
JoeC
here are pics of my 78D2
looks original but has some surface rust
so far it looks like 88D3 is the latest 4 digit code and 108D41C is the earliest 6-7 digit code ?
We haven't been keeping up with it, but are all these '69 Shifter bodies marked '3138', whether early or later ??  Or did they change the model number along with the mfg code  in the September '68 timeframe??
suturb110
My 88D3 date coded shifter also has 3138 stamped on the front of the shifter body.
Most if not all should be 3138 bodies.
I also asked the 69 Firebird guys about shifters. Nothing yet.
jdv69z
So where's the 3138 stamping? On the front if I'm under the car looking front to rear?
Jimmy V.
suturb110
yes on the front on the shifter.
JoeC
3138 is the Hurst part number just for that stamped part that makes up the outside case
It was used on many OEM shifters (Camaro Firebird GTO and others)
Hans L
Here you go - '69 Z, 04B VN, M22 trans:   9D53D
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Hans - Can you check to see if there is another digit before the 9 please? It may be very lightly stamped.  Thanks!
ZLP955
Is that a faint '1' before the 9D53D?
Tim in Australia.
Hans L
Quote from: bcmiller on April 25, 2016, 02:02:09 AM
Will do.   I'll have to crawl under and see now.  The shifter is on the car....but when I blew up the pic above, there does indeed seem to be a faint 1 before the 9...
'70 Camaro SS L78
