Holley Carb Date Code
Started by cruizin69, April 11, 2016, 11:07:25 AM
cruizin69
What would be the date code on Nov or Dec 1968 holley carb?
69 Zee
'69 Z/28 RS Cortez silver/black with endura bumper, U46
'69 Z/28, X77 Dusk Blue, white top, all orig, under restoration
'70 Plymouth Superbird, Limelight green, 45K miles
cruizin69
No that information does not help.
Example 802 1968 Oct 2nd week,911 1969 Jan 1st week, what number would be Nov and Dec.
The date code was only 3 numbers it changed to 4 numbers later on.
In the three character system October is 0 [zero] November is A December is B.
Did you read the link Darrell posted?
Quote1967 through 1969 Holley
The identification number and the date of manufacture are stamped into the forward vertical surface of the air horn. The three digit date code is broken down with the first number being the year of manufacture, the second number (or letter) being the month of manufacture (1 through 0 for January through October, and then the letters A and B for November and December), and the third number being the week of the month. Service parts assembled 1973 or later will have four digit date codes.
cruizin69
cruizin69
Yes I did read the post but did not see were it said about the numbers and letters.
69 Zee
Quote from: bertfam on April 11, 2016, 02:33:47 PM
Thanks Ed, you beat me to it.
Btw.. If you go to the "CRG" main page and look to the bottom right corner. You'll find a search window.  Leave the CRG checked and type away.  You'll mostly likely find your answer thru a previous thread or on the data info.
and welcome  :)
