Hurst blower motor cage ?
Started by paulmanta, February 09, 2016, 01:27:47 PM
paulmanta
I have been fixing up the daily driver 67 Camaro and finally getting the heaters sorted, they were filed up with mouse food/nests and the flaps were stiff and there was no airflow so a complete job was needed.
Fenders off, boxes out, shop-vac used, then a dip in the disinfectant bath for a day or two and its all looking better.
One of the things I found was that the rodents had eaten the plastic fan cage so today I removed its remains and put in the used tin one I had in stock.
Closer inspection of the remains of the old one showed a part number and a Hurst logo.
Did Hurst make fan cages for GM back in the day ?  I am sure as I can be that this car has never been taken apart, all the sealer and nuts look totally undisturbed, the core was a Harrison that matched numbers with the car pretty well so I think this is original.
1968 Z28
My 68 fan has the plastic cage and also has the "H".  The "H" is for the Harrison radiator division.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
paulmanta
Is it !  Ah ha !
The Logo looks a lot like a Hurst logo, its quite small and probably where my mistake was made.
Thanks.
HawkX66
Here's the one out of my 69. You're right about it looking like the Hurst "H".
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
L78 steve
That is Hurst. Has the shifter through the H.
69 Z/28 Dover White. SOLD
HawkX66
Quote from: L78 steve on February 10, 2016, 11:17:15 AM
Good call. I was wondering about that.
Dave
Semper Fi!
QuoteThat is Hurst. Has the shifter through the H.
Negative. That's the Harrison Radiator Corp logo and it's not a shifter but a thermometer! (Go look at the HARRISON name on your radiator!!)
VERY similar, but not the same.
L78 steve
Jeez, I thought I knew everything. Thanks Bertfam.
HawkX66
Quote from: bertfam on February 10, 2016, 12:57:14 PM
Well wuhduhyou know... Harrison does make more sense. Thanks.
Dave
Semper Fi!
Thank you Ed. Great work...again!!!
   Just a friendly reminder, if this is a one wire motor (it should be for '67) then don't put too much paint under the screw head areas on the blower housing otherwise there will not be a good electrical ground to the outer heater cover housing, which is then grounded to the chassis. Also for '67 the two heater cover housing to body bolts w/captive flat washers didn't have star washers as it did in the latter years to ensure a ground to the chassis. At least for April and May 67 that is. I found this out after installing and testing my heater motor and cover which have been repainted and found the paint interfered with having a good ground.
Test before you reinstall the fender so you don't have any surprises later.
HawkX66
Quote from: Mike S on February 10, 2016, 01:25:49 PM
Thanks for the reminder Mike. My 69 is a one wire and as you can see in the pictures I did a good job painting it... I'll have to make sure the screws are making good metal to metal contact.
Dave
Semper Fi!
I don't have anything to add except that I would like to have a better one for a 69. Ohio mice are very good at destroying!
HawkX66
Quote from: ko-lek-tor on February 10, 2016, 02:55:56 PM
I hear you Bentley. I got lucky with a lot of things. This is how mine sat for many years. How a branch didn't take my SS or the Z out is beyond me. We had plenty of field mice too.
Dave
Semper Fi!
paulmanta
I am glad this discussion went as big as it did, my cage was eaten and the logo was dirty and scuffed so that's why I thought it was Hurst.
Now I see the two logos side by side I can see the differences.
Thanks for the tip about the earthing, I had thought the one wire system was not ideal and was considering adding my own hidden earth anyway, now I definitely will.
Here is a pic on my cage :
