Original DZ block on E Bay
Started by HustleRussell, January 17, 2016, 09:45:30 AM
L78 steve
Decked .050 would still be able to read the stamping.
69 Z/28 Dover White. SOLD
The ad read 'decked 0.005" ...'   which isn't much, but it's clear the stamping is gone.... so it was a much deeper cut, probably with the intention of removing the original stamping (and support his current claim)...
Probably wasn't a DZ block to start out with.
L78 steve
My mistake, .005 not .050
I'm told if a numbers block must be decked it can be done in a slight angle to save the stamping.
A machinist can also stop the machining short of the stamped deck....
69ZX77MP
1969 Z28 X77 Lemans Blue 03D
MR GMPARTS
Quote from: 69Z28-RS on January 17, 2016, 01:05:38 PM
no it ws a ce   over the counter blk on the pad  from gm parts palnt ,
HustleRussell
Russ
68 RS
69 SS
Probably not on  CE block. If it was an original block it could have the VIN by the filter, but that wouldn't tell you it was a 302
dale_z28
Quote from: 1969Z27 on January 26, 2016, 03:24:50 PM
  Relisted.
http://www.ebay.com/itm/1969-Camaro-SBC-original-GM-302-engine-block-DZ-3956618-4-bolt-main-A169-/131706682577?vxp=mtr
Could there be a vin stamp on oil filter boss?
Kerns is in my town, as far as I know is well regarded as a long-time speed shop. If anybody has questions maybe I could stop by and take a look for you?
'69 X33 02D   Since 11-29-'77
~Ben Franklin
Quote from: MR GMPARTS on January 26, 2016, 02:32:00 PM
Actually the CE stamping was only used for 'warranty replacement engines; not OTC blocks/engines..  those were unstamped.
dale_z28
I stopped last night and checked it out. It had no VIN that I could detect. Otherwise a decent-looking block for a project. Auction ended - no sale
~Ben Franklin
369
Hey--are these things really worth all that much? I have one that I was just going to use in a 302 hot rod build....is that not a good idea?
Quote from: 369 on January 30, 2016, 09:51:51 AM
I don't think a 4-bolt block (prior to machining) is worth that much without some 'original stamping' value (which that one did not have).   now..  IF the machining (boring, line honing, etc) had been done and done by a good machine shop you trust, then it's well worth $500..  as the machine work would cost close to that.
I have a 4-bolt main 350 block from early '70's that had been in my shop since early 80's which I disassembled late last year and had the local machine/speed shop check out (was thinking of a 383 for my EC)..  no cracks or other problems; std bore which the machine shop told me would be good with an 0.020 overbore which I'd put on someone for $200.. OBO...  :)
