67 4 speed reverse switch
Started by hrascoll, December 12, 2015, 06:29:06 PM
hrascoll
does any body have a picture of a installed reverse switch for a 67. the AIM is not very detailed. I am having trouble with the holes on actuator rod not aligning up.
Jek9016
Here is a picture of mine.  It's a Saginaw tranny.  I'm having trouble with the shift rod rubbing the side of the switch when i use reverse and shorting out.   Apparently there is another set up that mounts a bracket on two bottom bolts of the cover and uses a short rod that attaches to the reverse linkage.
Jek9016
I just ordered the hurst universal switch that mounts on the shifter under the 4th gear stop bolt
.  Will let you know how that works if interested
Quote from: Jek9016 on December 19, 2015, 10:07:52 PMApparently there is another set up that mounts a bracket on two bottom bolts of the cover and uses a short rod that attaches to the reverse linkage.
That's the correct configuration used in production - it's shown in detail in the M20 section, sheet A7, View "A" in the 1967 Assembly Manual.
