AAW 69 Engine harness differences
Started by BillOhio, July 14, 2015, 01:30:35 PM
The bracket which bolts to the bell housing is coated on the original and is bare on the repro, are they using black harness clips again or are they still white?
BillOhio
Is the coating a paint? One they sent was cad plated. I just got the harness to my starter, header had worked on it a bit.
1969 Z28s, Burgundy and Rally Green
1968 RS 327 4 speed
1970 Z28 M22 4:10
1969 RS legend certified
Its coated to keep from cutting the wires..  MY original harness on the 67 & both 8's are the same as what James posted above.
BillOhio
Ok yeah the new one wasn't.  I thought I might swap mine
1968 RS 327 4 speed
1970 Z28 M22 4:10
The wiper motor wiring as mine came exactly like the original. I used my original to make up a test set up. I need to check that bell housing bracket (pretty sure I used the original)! Thanks James!
BillOhio
Wonder why the 69 is different when chick's has the same colored wire and connector as mine? Shaking my head!
1968 RS 327 4 speed
1970 Z28 M22 4:10
69pace
The plastic can be changed out easily if the brown bothers you or you can remove it, paint it and then reinsert the leads. ;)
I'll have to look at my jumper wire, thought it was blue.
TeamCamaro - Moderator
BillOhio
Guy I talked to acted like mine was made wrong. I was like well it needs fixed!
1968 RS 327 4 speed
1970 Z28 M22 4:10
