Caveat Emptor..another
Started by william, July 21, 2015, 08:23:40 PM
http://www.ebay.com/itm/Chevrolet-Camaro-Z-28-/141724558408?forcerrptr=true&hash=item20ff712448&item=141724558408#
Claims to have a non-OE but "correct" DZ engine. Engine is stamped V0226DZ 19N553055, cast B249.
N553055 was final-assembled on or about December 3, 1968. Somehow the engine time-traveled and was factory-installed in a car built 84 days before the block was cast.
69 Zee
JMO.... both the VIN and the DZ stamps look bad.. characters are out of line !   :o  VIN in wrong location  :-\
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
jdv69z
So I,m assuming these dealers deliberately do not show the trim tag?
Jimmy V.
Some do, some do not.
In the case of this car it is photo #11 of the slide show. So I guess it is real.
Pad is a restamp - and as William points out, with a bad date and VIN!
124379N601813
Tag could be original.
Trans isn't.
